stuck grinder nut
drabe7
my brother picked a makita 7" heavy duty grinder at a flea market and we cant seem to get the nut off. i have been soaking it with liquid wrench. i bent my spanner wrench on it. the holes on it stripped and i realize i will need a new nut. how do i get it off. im thinking about welding a nut to it and taking my breaker bar too it. any suggestions
Hundojoe
Minnesota
Left hand thread maybe? Also try using a dermal tool with a cut off disk and try making cuts on each side of the nut. Good luck
D
drabe7
here is a pic of the nut
Big-Foot
Midlothian, TX
I have never seen one with right handed threads so that's out...
There are flats in the shaft under the disc to lock the shaft on most models, then a spanner that hooks into the holes.
If nothing else, take a bfh to the disc and shatter it which should release the tension on the locking nut..
D
drabe7
the disk on it is a very worn diamond blade
WQ59B
I'm in the same boat: stuck nut on a diamond disc. Spanner wrench isn't built to put 'unsticking force' on the nut. Spindle lock isn't very secure, either. In the future, I'm going to make sure I grease the nut/threads on these well. Haven't gotten mine apart yet.
Canadian Cowboy
MI
Use a hammer and strike the top of the nut a few times hard,make sure you strike the nut square with the hammer it will shock the spindle nut enough to help release it.
Once you do that clamp the nut in a vise make sure it is tight it wont hurt the nut than lock the grinder spindle lock so it wont spin and use the grinder body itself to loosen the nut.
Been there done that many times it works.
CC
mitusa
SW Oklahoma
Don't use the spindle lock....it's only a good way to break it. Use the flat behind the disk. I forget the size of the wrench it takes.
D
drabe7
thanks guys. i used canadian cowboy's suggestion and it worked great. thanks again
WQ59B
Got back to my grinder. Not even a sheet metal wrench would fit between the guard screws & the 'base washer' behind the disc.
Ended up clamping the diamond disc in a vise and striking one of the holes in the lock nut with a chisel. I had soaked it down with penetrant a few times and hammer rapped it, and the chisel broke 'er loose. Back to work.
