The Lazy Destroyer
Finishing up the wall insulation and next step is to run ceiling insulation between the trusses. Then put up some 1x4 furring strips on the bottom of the trusses until I can figure out what ceiling material to go with.
The batt insulation install is pretty straight forward but I have a question on how to proceed where the torsion spring is mounted for my garage door, as it interferes with where the insulation would be going:
Anyone run into this... and what did you do?
I guess I can put up a strip of plywood mounted to the side of the truss to raise up where the insulation would go, so it sits above where that 2x4 running perpendicular to the trusses is. Kinda cheesy but not sure how else to do it?
I still have the problem of it interfering with the furring strips and ceiling material as well. Not sure what I'm going to do about that yet.
