Injector Return Line Kit
JASTECH
Gering, NE
Ok, Here we go. 1988 F-350 7.3L IDI w/o Turbo. Need to replace I injector return lines, o-rings, caps and injector copper seals. What tools do "You" use for this job? Do you torque the pressure line down, if yes, what do you use and what is the torque setting?
I have this job to do comming this weekend so please advise. TIA
Thanks, JASTECH & Son
fancypants
When I did my 6.9L, all I needed was a line wrench, deep socket, extension, ratchet, pliers for the hose clamps and a knife to cut the new hose. I think I put some vaseline on the o-rings too. Didn't bother with a torque wrench.
hunterguy86
Central Texas
I did this job on my 93 7.3 turbo and on a 91 7.3 na. I used basic hand tools and and a tubing wrench for the injector lines. Simple and easy. Make sure you have a battery charger or the like. It took some cranking to get all the air bled off. These don't have a primer on them. Factory instructions is to crank until she starts, pausing to let the starter cool.
Some days I miss that truck but most of the time I don't lol.
J
JASTECH
Gering, NE
So no torque wrench needed for the pressure lines on top of injectors? I may mount electric fuel pump on frame by driver or if helpful a FASS?
fancypants
I'm no expert, but I don't think you'll need it. If you wanted to torque them you'd need an extension and crowsfoot wrench and would have to recalculate your torque setting accordingly. Somehow. I think. Or you could just tighten them down and look for leaks. You're more likely to have leaks coming from the return line cap to injector o-ring seal.
J
JASTECH
Gering, NE
Fancy, thought about that. The new systems are more hi-tech then these dinosaurs but these run w/o computers. I have read some use a socket over cap and mallot. Not good I think so i'll just try and push them in and listen for the "pop". I may buy cheap hose grip pliers to assist in line removal as my hands have issues. A good used set would be nice.
truckdriver
Miami,OK
Can you not prime the fuel lines by sticking a air hose in the fuel tank? That's how they do it on big trucks.
KEH
Like to hear more about the air hose in the fuel tank for bleeding. On older farm tractors with an injector pump, I have to crack the fittings at the injector and turn over until fuel bubbles out. Real pain.
KEH
J
JASTECH
Gering, NE
Never heard of air line to fuel tank. Thinking maybe a FASS or Air Dog system or the like for this truck if available.
crewchief888
NW indiana
you may be able to prime fuel lines and filters up to the inj pump by slightlypressurizing the tank.
i wouldnt think just replacing the return lines on the injectors you'd need much priming at all....
i could be wrong...
:beer:
ihateminimumwage
I suddenly thought I'd somehow wandered back onto the Oilburners forum without noticing :lol:
The return lines on these trucks are extremely basic. A line or combo wrench for the metal lines, small pliers for the hose clamps, a pick or small cutters to take off the old o-rings, a razor blade for the new lines and a generous amount of vaseline for the new o-rings.
Loosen the line nuts on the injectors (be careful not to bend them too far, they are prone to pinching and not cheap to replace). You can loosen them at the IP as well if they won't get out of your way, but it usually isn't necessary.
Pop the old caps off and pull or cut off the old rings. Use the old set of lines and caps to measure out and cut for the new setup. Generously lube the rings and upper area of the injectors so they're roll on smoothly. Get the upper one on so the lower will just slide right over it and not get stuck in the mounting space. 'Pop' your new caps (you'll hear it if they seal correctly) and lines on and tighten the line nuts down. All set!
It's easy to get it started if you unscrew the fuel filter and fill it to the top. It can still take a couple of minutes to start, and run rough on start up, but it'll work the air out quickly. Don't crank for over a minute straight at a time, with a 2 minute cool down in between; these starters are heavy and expensive to replace!
I made life easier on mine by installing a ball check valve from Lowes inline between the tank selector and the water separator. The valve prevents the fuel from bleeding back from the filter to the tank, so the truck starts right up after changing injectors or return lines.
If you start it up and the lines leak at all, you can usually pop them back off (without removing the line nuts) and pack a little more vaseline in there, usually within a few miles they'll seat and stop leaking.
Need any more details, just ask!:thumbup:
J
JASTECH
Gering, NE
mininumwage, That is a nice bit of tech there mate, thanks. What say thee on electric fuel pump, FASS or Air Dog/puppy? I will add the turbo later.
ihateminimumwage
Heard a lot of good with an electric pump, as long as it's a diesel rated and not just a cheap-o pump. The cheap ones will fail and leave you dead in the water. I've just stuck with my old mechanical pump, because the worst that happens when they fail is they dump some fuel in the crankcase and you have to do an oil change, but it'll still get you home.
FASS or Air Dog: I'm not familiar with the terms?
Mine is still NA, already installed head studs for when I have the funds to build a good turbo setup...
