First Impact Wrench, input needed please
unspankable
Hello board,
Brand new so please bear with me. I'm about to purchase my first pneumatic impact wrench and i was thinking about the CP 7748. I looked for reviews but couldn't find any. What does everyone think of this gun and CP's reliability in general? I was also considering the 8252.
Please Let me know what you guys think. I have a rusty old restore I'm working on outdoors with a 11cfm@125 psi portable 20 gallon compressor.
Thanks very much
texasprd
San Antonio, TX
Chicago Pneumatic is reputable (you probably already knew that!) - I don't know what the torque specs are (they were in metric on CP's site).
I have an IR231, which my 14 year old 20-gal. compressor runs just fine. Compare it's specs to the CP you have in mind, and if you're set on a composite housing, look at the IR2131.
Both CP & IR should give you many years of DIY service.
U
unspankable
200 is about the limit i can spend on this first impact. That puts the IR ti a bit out of my range.
pop pop
Virginia
I got a new one on Flea Bay for less than that $200. Check. Love the 2135TI if I got those initials correct :)
Chadwilliam1
Cincinnati
I really like my 2135timax. save up some more money, you wont regret it. I suggest buying the protective boot as well.
HaroRider
New York
IR 2135 can be had for less then $200 if you look around, for a DIY gun it has not let me down so far.
crewchief888
NW indiana
IR 231
been beating the **** outta them for years
bought one this year from summit racing,
$138 to the door, std delivery, arrived in 2 days
:beer:
Snapped-off
Indiana
I'm unsure of the model, but my dad has a 1/2" drive CP impact wrench. It's about 30-35 years old. I've always suggested CP and IR impacts.
Shadowdog500
Down the shore
X4 on the earthquake! I love mine!
I used a 20 gal 2hp compressor for all my air tools for years with no problems. You only need a big compressor to run things like bead blast cabinets, paint sprayers, da sanders, etc.
You only use the impact for short blasts on each lug nut so it really don't require a lot of air.
Chris
EddieSantor
pipsters
USA
What ever you buy, make certain that your compressor can put out enough air (CFM) !
No! You can run an impact with a tank of compressed air with no pump on it!
CFM requirements for air tools are only important if running continuously! The least understood concept I see on here.
Whether your compressor puts out 0.5 CFM @ 90 psi or 50 CFM @ 90 psi, the impact will get full power provided the tank is full.
Chadwilliam1
Cincinnati
assuming you have the right air hose. correct you don't need a pump. you can get nitrogen bottles to run your tools.
U
unspankable
Thanks guys i really appreciate all the help. This seems like a great board. I'll look into the IR 231 & 2135?ti and the hf earthquake along with the cp and see which one i can get a good deal on
pipsters
USA
Don't forget the 20% coupon @ HF. Brings the Earthquake down to about $75. I had a 2135qtimax ($300 gun) and the Earthquake smoked it.
dsmnickk90
Look into the IR2131 it has a little more power than the IR231 and is a pound lighter and 15dB quieter and is under $150
