What's on your walls? Neat storage ideas!
Honch
Danville, IN
Since this thread has made it from the walls to the ceiling....
A local clothier went out of business with a one million square foot facility full of rivet racks. I purchased thirty six 4x8x8 racks for $67 each, thirty five for work and one for me.
I used the top shelf rails to mount it to the ceiling and only had to add four small notches to the rails to allow them to hang from the rivets on the top shelf.
These pictures were of the first one I put up, they are in my other home which has a second floor above the three car garage making the ceiling floor joists. One rack was enough material to make three of these.
thatcher
i am trying to stop that pile of random notes and stuff on my benches so i drilled some holes in clothespins and nailed them up to a shelf. hopefully having this stuff hanging in my face will make me do something about it.
Victorymike18
North NJ
^ That's a nice solution, resourceful and inexpensive.
If you want to spend some more $$$ you can look for one of those strips that restaurants use to hold the order tickets.
thatcher
yeah im all about using whatever i find or have laying around. thats a good idea too though
BD1
north side
I like the clothespins idea. i got a couple of small pony spring clamps that I did the same thing with.
Steevo
43.49600, -112.04300
I have been struggling with what to do about all the cardboard fish on my workbench! Thanks for the idea!
:thumbup:
mryyc
Calgary, AB
Got tired of cans stacked 4 deep on shelving so I ran a couple of thin rattle can shelves along the wall so I can line them up side by side (or at least staggered when I run out of room).
Works great so far. Just 5" deep 3/4" ply on galvanized braces, had the pieces lying around. Nailed and glued on a thin 1/2" strip of 3/4" ply as well to give them a little lip so nothing can get bumped off.
mdbeck1
Norman, OK
I keep saying that 'Space Creates Vacuum'. And there is proof... A new shelf with plenty of space and Vwooop! the shelves are full. Two more cans and you need a new shelf!
...or put a frame around it with doors that are about 4" deep and put more rattle cans on the inside of the doors...
Hannibal Hector
San Diego
I used up the space next to the door railing to hang up all my bikes...
1" pipe in pipe hangars.
and steel rod with bent hooks perpendicular from each other for hanging the bikes.
View media item 20141
Best thing is you can slide the rods on the pipe and put more bikes in a smaller area than fixed hooks in the wall...
View media item 20138
Deltaphi216
STL
this is such a great thread. I am in the process of finishing my garage. I have printed off about 10 pics from here to implement!
Thank you all for contributing!
lilredex
Toronto
How did you wall mount your welder? Mine weighs about 120 lbs. I didn't see your compressor mount?
Here is the original installation, misc angles welded up to suit. Might explain it a bit better, if not I can easily post pictures of the present installation (using those original brackets). Both locations used lag bolts screwed into 2 X 4 wall studs. Those in the last two shots, have been in place now for 20+ years.
This is the compressor shot I neglected to include the first time around.
Need more pictures.........just ask.
Brian_B_
North Central, AR
This is my start on storage. Low\no budget.
Packing crates for lumber and scrap laying around the shop for the rattle can rack and the air tools racks.
Morrisman
Angeles City, Philippines
I've started hanging stuff up on the walls, just to get it off the floor mainly. I'd like to get the ladder and trestles type stuff down some day, but the seats and gas tanks and things can stay up there as decoration. :D
I'm not a fan of open shelves a such as they just collect so much dust from my grinding and welding and woodworking and stuff. So I've built several large plywood cupboards for smaller stuff. Things are slowly getting sorted out and put away, just need to reduce my pack-ratting instincts....
But I do have tool boards behind the main bench for commonly used tools.
An extractor fan will go where the two concrete blocks are stood, eventually.
I've only been in this shop five months, and it's still in chaos really, so time will tell how it progresses. :D
LSU
"Built a cabinet for spray paints. Thinking I should've built it a little bigger. Had more cans than I thought. Amazing how much I had in every nook and cranny. A cabinet like this might actually save me money. Won't be buying paint that I already have."
If not too much trouble, would you mind post the measurements for the cabinet you built?
Also, is that a dowel across the shelves to keep the cans on the shelves?
Thanks.
76cruiser
Wyoming
These are chrome wall racks that I got from a closed bakery. I was able to score three 8' units and four 6'. It is hard to tell in the picture, but the have an angled bracket that connects the chain to a top mounted 2x4. not bad for free!
thatcher
At least you know you won't run out of shovels any time soon. :D
totally! when it starts snowing i leave one outside every door. that way i dont have to carry them through the house and one is allways there when you need it. cuts down on the procrastinating too! no excuses the shovel is there, your there and so is the snow, might as well get some excercise. the plastic ones are for the wood decks and the metal is for the concrete.
good score on the racks! chrome or stainless? i love getting free material!
MetalMangler
Upstate NY
i'm surprised some of the welders out there haven't made any cool storage racks or misc items.
Not mine by any stretch of the imagination, but since you mentioned welding, and since I just watched this earlier today (yesterday)...
And one more that got me drooling :drool:
I'm in love, but too poor to do anything other than wimper in jealous unworthiness!
MM
TRC51
Well, I was looking for some suggestions on cabinets and along the way decided that I would post my idea. No where near the caliber of genius work that is in here, but it was my small victory (although short lived).
I was getting tired of the pile up of shoes as you enter our home from the garage. I needed a way to store shoes in the garage, but obviously needed to keep them close to the entry door. During my garage remodel I decided I was going to build a small entrance porch to make it easier to get into the house. During that time I came across a file cabinet that seemed to work perfectly in the spot I needed. Below are some pictures. The cabinet fits perfect in the area next to the door, the shelves are just deep enough for the shoes and I can adjust the height of the shelves as needed.
daveroy
Omaha NE
well, i was looking for some suggestions on cabinets and along the way decided that i would post my idea. No where near the caliber of genius work that is in here, but it was my small victory (although short lived).
I was getting tired of the pile up of shoes as you enter our home from the garage. I needed a way to store shoes in the garage, but obviously needed to keep them close to the entry door. During my garage remodel i decided i was going to build an small entrance porch to make it easier to get into the house. During that time i came across a file cabinet that seemed to work perfectly in the spot i needed. Below are some pictures. The cabinet fits perfect in the area next to the door, the shelves are just deep enough for the shoes and i can adjust the height of the shelves as needed.
genius!!!!!
nrs2420
I'm no expert but in the last picture you have boots stacked on boots. I think you have a couple open spots where you can put them lol
Great idea, I may be stealing it.
TRC51
Great idea, I may be sealing it.
LOL.... I wasn't done putting all the shoes in when I took that picture. Like I said, the victory was short lived. I have a wife and two kids. All those spots went away quick.... and for some reason my shoes are no longer in the cabinet, but on the porch.:rolleyes2 Just when you think you've made enough spaces.... someone makes more shoes.
bparksntx
Frisco, TX
My storage cabinet for spray paints, cleaners, etc. Not as big as some that I've seen on GJ but it fits my space nicely. Built out of 2X4's, 1X4's, and a piece of clear lexan that is painted red on the inside.
The white spot in the center is the flash from my camera LOL
I have a bunch of decals and stickers and I wanted a place to stick 'em.
http://garagejournal.com/forum/showthread.php?t=94374
I'll post some more pics once I get some stickers on it.
