Best Air Line Couplers
wharvey
North Carolina
Hey guys,
I'm sick of my quick couplers developing air leaks after little use. I've bought the from Northern Tool, Harbor Freight, Lowe's etc but they all eventually ****. Any advice on the best, most dependable couplers I can get out there? My compressor is this one:
I haven't run a permanent pipe yet and I use 3/8 inch line.
Thanks!!
Wayne
mrtoolfool
Iowa
rodm1
Over all Milton connectors are the best do to quality and availability. Be for you decide I suggest you travel to most hardware and auto parts stores in you area and buy what they all have in common. Eventually some will discontinue that line. Consider using 3/8 connectors if the high flows aren't available in good supply.
bsaint
Manchester, CT
Legris C9000 safety couplers are my favorite, but they only come in plastic external bodies. I thought my brother found stainless ones but I cant find them. They connect with standard industrial style air fittings.
bowtiepro3
Northwest of Minneapolis
Prevost makes an awesome coupler as well, they outlast the brass ones 4-1 and most of the steel ones by at least 2-1 with the way they are designed. Not cheap, but well worth the cash in my opinion.
RECox286
South Joisey (yeah, that is part of the USA)
I'm sure that there are other than Milton couplers available, however, for what it's
worth, Milton is available where ever you go. The others (?) , I guess you have to
really hunt for them. I have been a Milton kind of guy for 35 years, and yes, I have
worn them out. The shell of the coupler remains intact, but the replacable "faucet
washer" does suffer over many years of use. The good thing is the washer is reversable.
I bet you would wear out too, given as much use as my couplers get.
Uncle Bob
RacerX
Caldwell, Tx
Another vote here for the Milton "V" connectors. I've been swapping over to them from my previous Milton "A" style and various no name A style that leak like crazy. The no name ones tolerances are way off on the machining.
Nice thing about the "V" is the "A" will also connect to it if you have a tool you haven't changed the connector on yet. It leaks, but can still get the job done.
barney rubble
The "M" syle Milton also work with the "V" couplers but leak also some times.
AndyA
Texas Near Dallas
I use milton m-style.
I also have a few of the prevost pushbutton connectors, m-style. Those are great for use with gloves. Just push the connection together until it clicks, no fiddling with pulling back the ring. The pushbutton release is large enough to operate with gloves also.
fflintstone
MOFnowhere Mi.
I vote for the Milton H couplers, they are the high flow type (3/8 body) as well.
I am not familure with the V couplers everyone mentioned. Campbell Hausfield sells the 3/8 body I/M which is the same as the Milton H series. I have been running these plugs for 15 years now and love them.
thewal
I am curious about something, I use the P styles couplers S1809 from Milton rated at 68 SCFM but I heard that the V style has 74 SCFM and are easier to connect than the p style. I also noticed that the p style has a larger hole than the V style s760. My question is what is better in terms of performance at the tool. How is the V style have more SCFM yet it is smaller in diameter.
Can someone assist with this question. I want to utilize the power of my air tools as they are all 1/4 inch NPTM.
Thanks!
TwoInch
NW INDIANA
id assume that the discharge outlet of the fitting is not the most restricted point of the coupler. the female coupler probably is where the restriction is.
Speed-Racer
I like the Milton A style. You can push the fitting on the coupler without pulling back the sleeve. Do a search, this topic comes up occasionally.
ILDurable
Homer Glen
As everyone else has been saying, Milton would be great to go to. But also check out Amflo! High quality and they have a nice, high flow to them.
thewal
I agree that milton is the way to go but i am just debating to stick with P style or V style couplers.
devoncoolman
quakertown pa
I use the Milton M style. and only genuine Milton products only way to go. I drop them throw them and abuse the **** out of them and they still out last the Chinese one 20 to 1 and don't leak. It really doesn't matter what style u pick just pick whats available. The "M" and "A" styles have been most popular in the auto industry for years. the Lincolns are finaly starting the disappear. Always hatted those. lol
TwoInch
NW INDIANA
v style couplings are high flow. they have a larger inside diameter. iirc, they were designed for HPLV sprayers...
thewal
are they better then the P style? P style diameter is slightly bigger. but in terms of scfm the V is rated at 74 compare to the p at 68, not sure how since the diameter on the p is bigger.
TwoInch
NW INDIANA
im assuming the actual restriction point is in the female coupling and not the actual diameter inside the male "port" the P style is a 3/8ths coupling, and the V series are standard 1/4" couplings. the Ps are much larger in overall size, and will add much bulk to the end of your airline and tool.
either way, 68scfm and 74scfm are close enough to not matter at all for anything garage related.
blacK20
Like already mentioned the nice thing about V couplers is that they'll accept M and A fittings as well for tools that you don't want as much power on. I use V fittings my impacts and A fittings on my ratchets and drill etc.
RCL
Had a cheap offshore coupler on my compressor that was really irritating me.
Just installed a new Milton and problem solved.
thewal
The one thing that i hate about the p style is that they are a pain to connect and disconnect plus they are bulkier.
TwoInch
NW INDIANA
i dont think i have ever heard of someone wanting less power in an air tool... especially ratchets and drills. generally you want them to be running at full potential.
