cmandp
I have a Companion 101.03520 table top drill press in need of some work.
It is very similar to this one I found on vintage machinery...
http://vintagemachinery.org/photoind....aspx?id=11200
The problem is that the spindle (and maybe the quill in the head too) has noticeable movement when you grab the chuck and push it back and forth. I can see one bearing just above the chuck arbor that I assume to be at least partly at fault.
My questions are...
What parts can cause this play in the spindle?
Also could someone either describe or point me toward a thread that shows how to take this thing apart? I have an idea, I just don't want any surprises.
Am I correct in thinking the quill has a No.1 Morse taper for the chuck arbor? I ordered some Jacobs chuck removal wedges which I presume are about the only way to separate the taper. As far as I can tell this press does not have the original chuck, on it now is a #33B Jacobs chuck and what looks to be a self made arbor. I can get pictures if it helps you guys.
Any help appreciated.
My questions are...
