Moving Factory Lug In Panel
Spudland_Dave
Maine
Is it permissable to move a factory lug in a panel?
Installed the panel last weekend, last night I was tinkering...installed the ground bar and lug..got to lookin and thinkin it would be easiest if I moved the Neutral lug down to the bottom of one of the bars (bottom feeding my panel). When I pulled the set screw I noticed they attached that lug with a Torx...no biggie tool wise for me, but got to thinkin maybe theres a reason they wont want it moved.
What I'm thinkin is I put the ground lug at the bottom of the new bar, move the neutral down to the bottom and then loop the 2 hots up and around on top.
2 Pix attached...one is of my panel installed...the other is a random pic I found online and edited quickly to illustrate what I mean.
'04 Cummins
MD
Turn the entire panel over with the main breaker on the bottom... Then you don't have to loop the hots or move any lugs.
Spudland_Dave
Maine
I thought about that...one of my buddies has his that way...My OCD dictates the Main is at the top... :lol_hitti Dont ask me why...I just think "thats the way it should be"
malibu101
Walnutport PA
I have used a panel like that "upside down" that passed with no problem.
As I understand it-
IF the main breaker handle moves horizontal it can be used any way.
IF the breaker handle moves vertically, up must be on and down must be off.
Spudland_Dave
Maine
OCD is my own Obsessive Compuslive Desire for things to be "Just so"...No inspection, no code here. I could mount it sideways and inside out if I wanted too. I just think it "looks better" and "It should be" with the main at the top...
dave*99
Coastal NJ
Think of it this way, you want the INSIDE of the panel to look good. That will happen if you put the main at the bottom.
