Miller X clamps are pretty cheap.
Check out
www.surpluscenter.com
last time I looked they had dozens of different types and their pricing is usually the lowest or close to it.
Jim
The term "cheap" is relative I guess. I didn't think $45 for a clamp was that bad. The only issue I have with the x clamp is they are designed for their table which is only 3/16" thick if IRC. It didn't look like it would be too much work to modify the roller to work with the 1/2" plate I plan to use.6" clamp is $45? I want 4 to start so around $200 total with shipping. Ouch.
I use ones like these and they work well. I picked them up at Princess Auto for $25 each.
Is it Betsy or Bessey (brand name)? The ones I got are "Task" brand. I've seen Bessey brand at Acklands-Grainger for about $90 each. The Tasks, at $25 each, work just fine for me.... Betsy clamps, very handy.
Yeah if I can't find a better valve $45 isn't bad. I'll probably go with 1/4 or 3/8".The term "cheap" is relative I guess. I didn't think $45 for a clamp was that bad. The only issue I have with the x clamp is they are designed for their table which is only 3/16" thick if IRC. It didn't look like it would be too much work to modify the roller to work with the 1/2" plate I plan to use.
A couple more:
