I was thinking the same. That color is a perfect fit.That's a beauty. I really like the color.
This isn't mine, but it may be if you guys tell me I'm an idiot for passing it up. 3 1/2" Wilton, saw it at an antique mall this morning for $75. The jaws were a little worn, but otherwise in decent shape.
Can't really talk down a dealer who isn't there. I'll pick it up tomorrow.I don't think there is too many people shopping for a vise at an antique mall.You are an idiot... At the very least you could of tried to talk them down some... You could clean it up a little (don't even have to paint it) and resell it on ebay for a lot more...
Nice Rock Island!! How much that set you back?
Cleaned up the Taskmaster 5. Trying to sell it on CL and Etsy. I'm asking too much so that I have room for negotiation. I prefer a naked vise, but from my experience, color sells.
Thought I would add my collection to the correct place. Biggest is the C. Parker at 60# followed by the Columbian at 45#. have a couple more but no pics.![]()
I think what you are asking on CL is very reasonable. Its in excellent condition
Here is a recent find. A "Made in Japan" Craftsman with 6 in. jaws. (I am not sure I would have figured that out without the big metal "6" sign pinned to the jaw.) Hard to find any info about this. I cleaned surface rust from the slide but have not decided to do more. Almost as beefy as some of my old American iron and very well made. Castings are nicely done and the machining is great. Tight tolerances and very smooth after I removed the rust. It was about $.50 /lb.
Especially that Morgan 60! Look at it next to that Dewalt bench grinder!!!!Here is a recent find. A "Made in Japan" Craftsman with 6 in. jaws. (I am not sure I would have figured that out without the big metal "6" sign pinned to the jaw.) Hard to find any info about this. I cleaned surface rust from the slide but have not decided to do more. Almost as beefy as some of my old American iron and very well made. Castings are nicely done and the machining is great. Tight tolerances and very smooth after I removed the rust. It was about $.50 /lb.
Forum lurker and first time poster.
I found this thread as I was trying to learn a little bit more about a Samson vise I picked up. Thanks to member posts and an old Sears Catalog ad, I know the vise I picked up is near 100 years old and probably fairly commonplace back in the day.
My no brand Chinese vise thread recently failed and instead of picking up something brand new, I felt a penchant for old US Steel. Yes the vise is not perfect, has a few grind marks etc but all that gives it character as far as I'm concerned.
Here's what I picked up:
The provenance of my Samson 5224 was a machine shop on a large farm in Wisconsin.
While I normally use Aircraft grade industrial paint stripper (e.g. Klean-Strip Aircraft Remover), I was curious to see how the oft mentioned and urban legend of oven cleaner as a paint stripper and degreaser in one would work. What better way to test a paint stripper than to let it have a shot at 100 years worth of multiple paint layers. From good old lead based paint, primer, and rattle can layers - this vise had a bit of all.
Simple spray on application outdoors:
I waited about an hour after the first application and hosed off the cleaner. Impressive results. The oven cleaner had cut all the layers of paint and showed bare metal in most places. The primer this vise had seemed to be the toughest to remove. Easy enough : spray it with oven cleaner and let it stand overnight. I hit it with the power washer in the morning and this is the result:
Pretty impressive for Oven Cleaner.
The paint, grease and even the resin drip - all gone.
Dropped the vise in Metal Rescue overnight and hit the jaws and anvil with a wire wheel real quick:
Overall I was pretty impressed in how well the oven cleaner worked.
Not bad for $4.81. I'm always curious how the 'home remedies' hold up. I've boiled my RD's carbs in lemon juice and de-rusted tanks with toilet bowl cleaner as well. Generally the well discussed ones hold up nicely.
(Big fan of Metal Rescue btw - if you have not tried it, it is by far the best rust remover I have ever used. Paint safe as well)
As to the Samson, it's now my everyday small shop vise
Great board with awesome threads. My garage is nowhere near worthy but damn there is lots of inspiration here!
cheers
That is really interesting about the oven cleaner... I'm definitely going to give that a try soon!
Picked this up the other day its a 7'' Athol standard no.96 my scale is broke but i think its around 180 to 200 pounds...
That's a beauty BRAX, well done!
Zoom
You **** Brax... Are you going to keep or sell it?
Do you have a model number or anything for this vise? I have been looking for a Yost for some time but after seeing this one restored, I think I will be on the look out for one of these instead.
looks like a 014 or 013 1/2. The later ones has an inset square with all the mfg information and were labeled 930, 935, 940
azcactus, very nicely done on the starrett
