Vidmar cabinets
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I don't know how the keys work on the Vidmar cabinets but I have a key that anyone is welcome to. I don't know where I got it from as I don't have any idmars. I know that one Kennedy key will work on many boxes as they are keyed the same. The number on the Vidmar key is A 16 / 1219. If you have a Vidmar cabinet and the number matches your key, send me a PM and I'll send it to you. The keys aren't one that can be cut at any key shop.
Bull
My Vidmar is missing the key! Let me see if I can find a number on the lock later. I'll get back to you!
boosteddsm92
MD
FWIW, the Vidmar keys go from A1-130 or so. I just pulled the lock on mine last week, got the code, and ordered a couple keys from Stanley for ~$7 each. Here's the PDF on how to do it. All you need is any small key or a small screwdriver. If anyone has problems PM me and I'll try to help. Took me a while to figure out how it works but of course once I did it was easy.
Bull
Kevin, I found an engraved number on the cylinder but it doesn't match the number style you posted. It looked hand-engraved though and not factory stamped. Let me see if I can pop the lock out and get a better look. That PDF above should help!
Bull
The hand engraving is factory. Mine was by hand also.
Ah! I didn't write it down because was convinced I would remember it. Bad idea. I seem to recall the number being something like E-A5 though, which doesn't mesh with what people wrote above (the E part, I mean).
kirklandkie
Connecticut
I know this post is ages old but I just got a vidmars with an a16 lock. you wouldn't happen to have held on to that key for all these years would you?
Kirk
Shiftless
East Bay SFO
Kirk
FYI
Don’t expect an answer.
Kevin54 got into trouble on GJ after posting some political comments. He got mad at being called out on it and says he’s quitting GJ.
