What would you use it for?
DanarchyCustoms
Hudson Valley, NY
Well first and for most you should continue to use it as a koozie. Secondly if you need an awesome mail box post, I'm sure you could weld a few more pieces to it.
C
CAOS
Land of Living Skies, Canada
Well I have been convinced to put it towards something other then as a base for a bench grinder. Once I turn it into some art I will post some after pictures!
ruen999
i would be looking for the matching smaller? gear. once i had that i would give it another thought.
thundermug
usa
I've got a 50 pound City of Chicago sign stand waiting to be used for something. Now I know: vise/grinder stand.
elevator joe
MN.
Seen one (brass) cleaned up with legs and a glass top. Cool table,pretty heavy though.
BFBOB
Speaking from experience, I would use it as decoration. As Is. I like old cast iron pulleys, handwheels, gears, etc,. and just like them sitting around. Wife does too - we go collecting together.
pop pop
Virginia
Use it as a base and have several tools mounted on bases/post that slip fit into the hub.
leon renaud
North Eastern Conn.
I've been using a gear like this for over 20 years as a base for the Champion blower that feeds my forge ,It works great my blower stand is rock solid yes still easily moved by rolling the gase.
Richard D
Texas City, between Houston and Galveston
Good deal, that would have been a waste of a cool piece. If you are a bad ***, you could bend the ends of three pipes just right and fit them in the holes from underneath for legs.
