Evapo - Rust
wrenchr
I bought this yesterday from HF, I'm very impressed with it's result's!!!
I soaked this overnight!!
I just dropped this file to see what happens. I will check in on it tomorrow.
chad s
Baltimore, MD
That did an amazing job on the breaker bar, are you gonna keep that one? Its a good one to have for your collection.
W
wrenchr
Yah all I did was rinse it with water per the instructions. I might keep them!!
W
wrenchr
It is not a manicure it is called cutting my nail's. Plus I have to keep them cut or I will bite them, it is a bad habbit from child hood!!
Vinko
Los Angeles
I used it too, on a series of steel 3 inch steel plates that had been black-oxided previously, but had some light rust.
In about 30 minutes, rust gone. (Unfortunately, will have to re-black-oxide the plates as well).
I like the stuff because it's easy on the environment and your skin.
rocketman
Chicagoland
I've used it for quite a while and the stuff is great. I use it to de-rust bolts and other hardware. You can reuse it if still somewhat clear. KEEP IT COVERED. It will evaporate and leave your tools, sockets in a bed of hardened sticky sludge in about a week. Speaking from experience here.
Once it's cloudy, toss it.
tatra
pirate contest city
does rinsing in hot or cold water make a diff?..............and what happens if you try to use a squirt bottle on say an undercarriage ?..........does it dry up quickly?.................and the sludge you mention, how hard is it to get off?...........have a few projects that something like this could come in very handy...............
tatra
pirate contest city
$$$$$$$$$$$$$$$$$$$$$$$$$$???????????????.........and we don't have harbour freight up here..................did find two local sellers just haven't called them yet.................will let you know when i find out how much we pay..........................
tatra
pirate contest city
seems our very own can. tire sells it for about 10 bucks a liter..........will picj some up on the way to work later. and let you know how she go.........
tatra
pirate contest city
saw that too first, just haven't found any local suppliers................mail order only??..........anybody have any experience with this or both?.............and do they sell through distributors?
64merc
Texas
I think I have something similar that I got from Home Depot. It comes in a spray bottle and it very gentle on the hands and has a very mild odor. I believe it is made by Krud Kutter. Like the Evapo-rust though, if you let it dry out the remaining liquid will get really nasty and hard. Plus, the part will get a nasty white film on it. Overall, I like it though, and it works.
W
wrenchr
This stuff is the real deal!! What do you think????
Before
After
Before
After
W
wrenchr
The file's teeth were clogged with rust now they are nice and clear and all I did was rinse. Now I will go to the garage and spray some light oil on it.
W-Cummins
Iowa
I will stick with the electrolytic rust removal it's almost free. Will not remove base metal the solution can be reused until you can almost stand on it, and dose not turn to sludge on the parts.
William....
bsakal
Royersford, Pa
I bought 4 gallons last weekend. In a large tub I soaked the carburetor off of my '69 Charger that has been sitting on the shelf for the last 15 years. It's a Carter AVS 4bbl. The linkage was nasty looking with rust, and the throttle plates would not open, the shaft was rusted. I soaked the carb overnight, pullled it out in the a.m., and I' telling you this stuff is awesome. The rust came off of the linkage, and the throttle now works freely. Even the choke-pull off did not get damaged by this stuff. So I soaked a cast iron intake manifold, some tools and such that got rusty over the years, they look great. :thumbup: Now I have figure out how to resize the pics so I can post them......
arthur1920
Another resource; I have seen some amazing photos from this stuff as well. I'm not sure how it compares to Evapo - Rust:
http://www.safestrustremover.com/
Check out the before and after!
I have this. It works. Slowly. Better if solution is warm. They recommend scrubbing in between. Do not use for cad plated stuff cause along with the rust it will take off the plating. also parts are prone to flash rusting because you have to rinse it off in water afterwards. On the plus side, it is very gentle to the parts.
Bead blasting and rinsing in Phosphoric acid etch is about 6 times faster.
I think a better thing is to rig up an electrolytic rust remover. I put a plated part with some rust in there and it took off the rust and left the plating.
HTH
SocketDeviler
Texas, 75050
Just a heads up, I picked up the 32 oz. bottle of Evapo-Rust at O'reilly's for $9.00 with a $3.00 mail-in rebate. Good price. I'm gonna try it out this weekend.
