torx plus & tamper proof torx
NC-Fordguy
I was wondering......
What applications does one find these types of fasteners on?
I have a small 4x4 shop and haven't run across any as of yet, but the newest vehicle I have had in my shop was the last year of the jeep wrangler tj (2007 IIRC) Most of the stuff I spin is still mainly SAE
I have a Napa gift card and was wondering if cashing it on these tools would be worth it given what I run across. I haven't run across to many folks who will spend 40k on a new truck and pound and trash it on the rocks
MikeNZ
Nissan Terrano Front guard mirror is held on with tamper proof torx screw, only one i have ever come across
afazz
Pittsburgh, PA
I helped a friend install a scope on his Barrett .50 cal rifle and all the screws were IP25 torx plus.
JASTECH
Gering, NE
I come across them alot on enclosed trailers, been more often on other things as time marchs forth. The smooth head makes it usefull in other areas too. I have a set in SAE & Metric. So needless to say they are worth having.
littletoes
NE Washington
It seems quite a few headlights are put together with torx, my wife's dyson vac, my rifles bottom metal are torx plus 35's.......chevy seat belts (and I think door locks!), are a special tool specifically for chevy.....I happen to have screwed up and bought two over the years, but I keep breaking those darn things!!! That blue lock-tight is tough!
Just had to rebuild part of my deck, and all the screws were torx 25's, talk about awesome. Not a single screw slipped....now THAT'S a change....phillips is defiantly better than standard flat bladed, but there are better options out there.
Just remembered, chevy steering wheels are put together with e-torx fasteners...
Just broke three t-15 Snappy sockets and hand driver on a friends .223. What a pain!
We have this one local gun shop that thinks they have to red-lock-tight every ring/base screw. Thought about calling 'em up and chewing some ****!
Ft.ValloniaStreaker
Southern Indiana
Don't get me started on those damn things! Rear wheel bearings on 95-02 Sunfire/Cavaliers you can usually get 3 of the 4 before you round the sholders off one of them if your lucky enough not to break your socket.....Snappy guy told me he replaces a few of them, and those are $230 a set......
rider9195
My Volvo s60 has lots of T25 screws on the interior. My most used bit on this car
metaleltr
Western Ohio
Chevy seatbelts, door strikers, and bellhousings--I believe these all use the same size bit.
Additionally ford bed mounting bolts-the ones that go down thru the top.
These are all torx plus.
davesnothere
phoenix, az
I've been seeing a lot of tamperproof torx on maf sensors.
And bathroom stalls... Glad I'm not the only one that noticed that.
bcradio
New Mexico
German cars... and most restroom stalls, Tamperproof Torx. It's hard not to look at the fasteners when you love tools.
Ha ha that is totally how I am. I go around and see if I can identify every fastener I run into and whether or not I have the tools to take it apart.
As to the OPs question: I have yet to run into any torx plus myself, but a few tamperproof here and there.
metaleltr
Western Ohio
One tip regarding torx plus, if a standard torx is kinda sloppy it is probably torx plus, these bits fit like a glove in their appropriate fasteners.
shoturtle
Frankfurt AM
my wife's vw has torx plus all over the place. They actually have torx, torx plus and xzn/spline.
Security torx are used in allot of electronic applications. There is security torx plus, but they are not very common yet.
wafrederick
Holton,Mi
Tamperproof T20 on GM mass air flow sensors.Torx plus 50 on for the 4L60Es with the two piece case,the bolts securing the bellhousing to the case.Torx plus 30,one bolt that secures the valve body to the case in GM 4T65Es
RedFordTruck
Id never noticed that I just thought they were torx! :lol:
I guess the guys at the Linex place use those sockets a lot then!
metaldad
nw indiana
you gotta be kidding.......... metric torx?
jvitez
Big Sky Country, Canada
No such thing as metric or SAE Torx, just Torx. Tamperproof Torx: seat belt mounting brackets, plastic engine bay shrouds (Euro vehicles and the Mrs. Chrysler Pacifica with the 3.5L V-6),
N
NC-Fordguy
Yea I was wondering metric/standard torx??? Every torx socket or screwdriver I have is stamped T-something, for instance T-20, T-55 etc
jvitez
Yup, T15 is T15, T27 is T27, etc. You may not use it much yet, but you will as the year of manufacture of the vehicles you see marches on. I'd get some, just to have immediately available.
Are you thinking of Torx sockets, or hand-driven Torx drivers?
N
NC-Fordguy
I have sets of torx sockets and some screwdrivers that I use on occasion
Some aftermarket parts for jeep upgardes have them. OEM that comes to mind is jeep windshield hinges, jeep roll bars and some gm brakes.
What I'm wondering about is the tamper proof torx and the torx plus fasteners. Those two I haven't run across as of yet
jvitez
Eeks, mis-read your post. Tamper-proof Torx is on seat-belt brackets. I haven't come across Torx-Plus yet, but I bought an OTC 3/8 bit set just in case, and it was something like $35, so if it saves me from running to a tool store in the middle of a project only once, it'll be worth it.
catsass
Torx on my 89 Buick park avenue door panel,94 Saturn brake caliper, pop up headlights same car.i have torx sockets, also e torx, security torx with the pin in the middle. They are very common. Id like to have wera Handled torx drivers!
Sent from my SPH-D710 using Tapatalk 2
rob0781
Canada
I've seen them at the playground while there with my kids and I remember I bought my first set about 10 years ago cause I needed them while swapping out a steering column on a foxbody mustang.
tool-guy
victoria, australia
Tamper proof torx have the little nib of steel in the centre of the fastener. All you need to do is drill a hole in the end of your torx bit. Or better still, buy them with the hole already drilled.
