Another torque wrench thread
I did a specific search for Torque wrench in "general tools discussion" and found well over 300 threads with torque wrench in the title wow! Couldn't really find a answer to my question through all that so here we are. Was just curious if some companies actually account for this 20% rule I have been seeing mentioned in a few threads?
At the moment I need a Torque wrench that can do 18 ft lbs, and 106 in lbs.
Here is a wide range of torque specs I would need to do also.
http://www.ls1howto.com/index.php?category=1
I just purchased a few torque wrenches off ToolTopia last Friday. Been reading good things about the PI split beams so I purchased one, just wish they had one that was below 20 ft lbs.
I ended up purchasing this, and I'll just do the conversion for the Ft lbs to In lbs when needed.
http://www.tooltopia.com/precision-instruments-c2fr600h.aspx
Precision Instruments (PREC2FR600H)
120 to 600 in./lbs.
Now bare with me my Math is terrible at times. So for the 20% rule I just times that by highest torque setting correct? 0.20 x 600 in lbs = 120 in lbs so they accounted for this? This tool should be accurate through the whole range?
So 11 lb ft, 15 lb ft, 18 lb ft, 22 lb ft, 26 lb ft, 30 lb ft, 37 lb ft, 44 lb ft
I should be covered with this Torque wrench correct? Still needed a torque wrench that could do 106 in lbs so I bought....
http://www.tooltopia.com/gearwrench-85051.aspx
GearWrench (KD 85051)
25-250 in/lbs.
This would only be good at 50 in lbs and UP? Lowest TRQ specs in the link posted above are that I need are 44 in lbs for the intake manifold and 15 in lbs for trans.
I know I could have just purchased one of the PI Beam/Dial torque wrench but for whatever reason I did not want to purchase one of those. Guess I will buy one eventually and try it out.
120 to 600 in./lbs.
25-250 in/lbs.
