Spudland_Dave
so now that the panel is in and hot in the garage, time to install circuits... How would you drill the top plate over the panel? I'm thinking one of 2 ways... either drill a couple 1-3/4" or 2" holes with a hole saw and run all wire thru that, or use a 1" auger and make swiss cheese of the top plate...I'd like to drill a bunch now so I dont need to worry about hitting wires down the road if I run more.
The truss load is perfectly stacked above the stud right there...so thats not too much of a concern... but by the same token, i dont want to go overboard and remove the entire top plate...
Even on the drillpress these days, I often use Holesaws.
