Removing potato chip grease?
diggler306
Saskatoon, SK
Had some friends over this summer, partying it up in the garage, playing flippy cup, acting like we're still young... and some potato chips got left on the garage floor. When cleaning up, I noticed the chip grease had transferred it self to the concrete. This made adult me sad.
My self diagnosed OCD can't leave those grease spots alone. My garage floor is only a year old and it still looks pretty new... so I'd like to keep it that way until I eventually finish it.
What the easiest way (product to use) to get the spots out?
djjsr
In the cornfields
I've found that lacquer thinner will dry up most oil spots. There's a few other chemicals that work as well. Most of them are pretty flammable. Use caution.
draglink
Hayes, Va
Have another party, play lots of flip cup, spread chips on entire floor
clean up next day and boo-yah, its all blended back in!
Edger
Melbourne Australia
You can use solvents like paint thinners to flood the spots and mop up with a rag while they are wet (hang the rag out to dry before disposing). After that wet with water, sprinkle laundry detergent powder on the area and mix with a broom, keep wet, rinse off or mop after 10 minutes.
Get to it quickly, it is just in the surface and will come out.
If it does not work 100%, repeat.
jayoldschool
Canada
Get a bag of Oil Dry. You'll eventually need it for something tougher than chips! Works like cat litter, but way better.
dankicksass
New Jersey
Brakleen cleans everything. I use Purple Power for the floor though. Not sure if that's among its intended uses, but it does a good job and doesn't smell horrific. Big fan of oil dry and pig mat.
turbowoodworker
Apex NC
Pull your car in over the spot, open the crankcase drain, rub it into the chip stain, then wipe it clean and it will look like an adult's garage again.
jhelrey
MN
Shi.... Chip grease would be the last of my worries in my garage.
malibu101
Walnutport PA
Same at my place. At least I can't drag that into the house on my shoes or clothes.
Maybe clean it up with some of the above suggestions and epoxy the floor to prevent future snack food catastrophies. :)
draglink
Hayes, Va
D
diggler306
Saskatoon, SK
Haha! I knew I would get razzed for this. You guys can keep your big manly oil stains... I'll stick to my clean, chip greasy floor. And yes it was Lays those bastards!!!
Thanks for the tips. I'll start with the cat litter, then go to burn the garage down after. :)
Chrslertech1986
I use soap to remove potato chip grease from my privates idk but i have never gotten it on the garage floor so idk id start with some irish springs bar soap
D
diggler306
Saskatoon, SK
Haha I never got a chance to try any of the suggestions, as the weather turned cold and snowy shortly after posting. The floor is caked in snow, ice, dirt, mud now so out of sight, out of mind until spring. :)
Garage Flooring
Grand Junction, CO
I think we need to have a discussion about if grinding or etching works better for potato chip grease :dunno: Then the usual crew can chime in about tiles being a better option, Jorgen can sell you Racedeck and I can sell you some Pour N Restore and some Roll Out PVC Garage Flooring :willy_nil
Only kidding guys. Seriously though +1 for tide
larry_g
oregon
My process to remove stains is scrub the area with solvent and while the floor is still wet cover with floor dry. The solvent holds grease/oil in suspension and the floor dry absorbs the whole mess.
lg
no neat sig line
mdkingsley
Chickamauga Ga
I feel your pain, my first stain was devistating. I had the return line off the hyd. drive motor on my Dixie Chopper. Came in the next morning and all the oil had trickled out of it. A HUGE oil puddle on the floor. Since then my F350 has done a good job of taking my focus off of it since it marks its territory everywhere it sits. I guess the point is make more the first one wont seem so bad. Or try everything from brake clean to fire, one has got to work.
