1/4-1/2" motor. If you can, set it up on a stand and mount it below...
So would a vacuum or similar type motor be too small? I think I have a broken vacuum around here somewhere.
My dad's grinder is very much like what is pictured in the first post. He has an old motor on a hinge to drive it. It's noisy as hell.
Most modern washer and dryer motors would be difficult to adapt to this thing. They don't use the old NEMA frame motors in appliances anymore. Many of the washing machine motors are 220V three phase.
How many know what that barrel shaped stone is for?Here are some pictures of the bench grinder I got off Craigslist on 9/28 for $5.
A lot of the newer washers have variable speed three phase motors on them. Not any way to use them on anything else unless you want it to run a washer cycle. Spin one direction, reverse, spin, reverse. etc. The controller block is built on the GE motors and it's programing is not suitable for any use on grinders. The older motors most had starter relays that would have to be used in any new application, all were reversable and some were two speed reversable . Older washers are really not a good source any more for motors. Dryers motors were usually less than 1/4 hp so they would not run a grinder either.
lg
no neat sig line
And where is the three phase power coming from? Damn few residential homes have three phase power to them...
The machines have their own VFD units built in as part of the cycle sequence controller. Almost every modern front loader uses a three phase brushless motor that looks and works almost like an old floppy disk drive motor, but is at least a foot in diameter. The drum is attached directly to the motor shaft, no belts or transmissions are used. Line voltage comes into the machine, gets turned into DC, and the VFD uses that to produce a three phase current for the motor. The motor turns slowly and reverses constantly for washing, and gets to turn over 1000 rpm for spin drying.
Unlike the old induction motored appliances, the motor from these newfangled machines is not readily usable for handy stuff like bench power tools n such. You need a purpose-built controller, and the motor itself is inside-out in many cases. The fields are stationary inside, with the rotor being external, kinda like a ceiling fan motor.
I used to always harvest the motors from discarded washers and dryers, clean them up and reuse them for buffers and other power tools and fans. Rarely was the motor in any tossed off washer or dryer bad, in fact, removed from the appliance the motor would run comparable to a new motor, even if the appliance was over 20 years old and well used (or abused).
Most washers used at least a 1/2hp motor, dryers 1/4 to 1/3hp. most induction motors from washers have two speeds, sometimes three, excellent for use as a power tool motor. The toughest things about using these motors is figuring out the wiring and a mounting means, since the motors were mounted into the appliances with non-standard means.
I'd have never guessed they would be using VFD on an appliance like that.Interesting, I guess I'm still in the dark ages for Washer tech!I'd have never guessed they would be using VFD on an appliance like that.
Hmmmm; This begs the question; If they have a VFD, could this be salvaged out of an otherwise dead washer, and be used on say a 1/2 HP regular 3 phase motor? forward and reverse, variable speed, what's not to like? (I'm asking as I have a place I could use that...)
