What's on your walls? Neat storage ideas!
lilredex
Toronto
i am trying to stop that pile of random notes and stuff on my benches so i drilled some holes in clothespins and nailed them up to a shelf. hopefully having this stuff hanging in my face will make me do something about it.
Couple of other takes on this idea.
PAL offers a magnetic version. I use them on the filing cabinet next to the desk.
http://www.princessauto.com/pal/product/8164303/Magnets/2-pc-Magnetic-Clips
Either Woodsmith or Shopnotes magazine ran a DIY version of this one using marbles.......but cannot locate the issue **
http://www.dailymotion.com/video/xgit0q_grabber-bill-holder-restaurant-cafes-bars-paper-rail_news
kartracer23
New Castle, IN
The ones from Priness Auto? I sell those for like 79 cents (with a client's logo). And honestly, anymore they ****. There is only one company that makes a decent one (One of my salespeople is out showing it to a client this very second). When they first came out they were great and then the competition started and the rush to make the cheapest was on. Now the magnets won't hold a single piece of paper up.
lilredex
Toronto
That is not the PAL version then..............their's contain a rare earth magnet and you almost need a crowbar to remove them.
They regularly go on sale for $1 ea.
GregN
Rogers, MN
would be cool to figure out the marble thing
My buddy uses a marble type one at his shop for customer receipts. Here are some options if you want to buy one:
http://www.globalindustrial.com/g/foodservice/table-service/check-racks-supplies/SanJamar-Check-Racks
http://www.amazon.com/San-Jamar-CK6548A-48-Inch-Slide/dp/B0002ZWJZW
http://www.wasserstrom.com/restaurant-supplies-equipment/Product_311410
The design is actually pretty simple. You have the flat part that mounts against the wall, then a channel (something to hold the marbles) attached to that. The channel where the marbles are located is angled towards the wall, which keeps the marbles pressed against the flat part on the wall. Basically, the marbles are trying to fall out of the bottom, but the gap isn't large enough for them to fit through. Then, the weight of the marbles is all that is holding the piece of paper. It actually works quite well.
stewie97
Just waiting for that next temblor, eh?
Paint some lines on that floor, 1', 2', 3', 4' etc from that wall, so you can measure earthquake strength by how far stuff gets tossed.
I did the same thing with mine but I put bungee cords across each row so nothing will fall out.
uniballer
bedford, va
I use old parts boxes with keys and pegboard with hooks. And I saw a homemade tire rack, I am going to do that next!
fstbusa
What did you use to suspend it from the ceiling?
2x4s lag screwed to the walls around the perimeter. Supported the front by drilling all thread up into the attic space and thru other 2x4s spanning across the trusses.
IONH
Central Massachusetts
Thanks for the response. I wonder if just the threaded rod would work for smaller supports which have no walls. I suppose it would have too much lateral movement then which could cause the rod to fatigue.
fstbusa
No reason to think it wouldnt
Modern Jess
Bay Area, California
Have I mentioned that I love this thread? I make a point of reading it from start to finish every three or four months, each time noticing something I missed the first time.
WhiteLightning
Philadelphia, PA
What's the advantage of having this over just putting the funnels on top of each other?
Cross contamination. Imagine having ATF on one, oil on another, and brake fluid on the third. You would have to clean each one prior to use. This makes it a little easier, although it does take up more space.
peelman
Seymour, Indiana
  • Lack of cross contamination that would result from stacking
  • Less mess and cleanup for the same reason
  • Various funnels simply don't stack
Somebody at one time mentioned dust contamination would be a problem with these (in most shops at least). I'd have to agree, but a smaller, similarly-functioning setup could be built inside a cabinet fairly easily to solve that particular problem.
dittle fart around
Vancouver, Washington, USA
Simple and cheap loft storage above th garage door.
I think we're talking about long term storage here. Not a lot of movement going on unless you live in earthquake country. You could always start with angle iron with a diagonal brace then use threaded rod for the middle supports.
abstamaria
Manila
A standard shelf
Here is a shelving system I installed in my garage.
There is nothing extraordinary about it, but it was easy to install and came with wall attachment brackets. It is handy for spare tires, wheels, Christmas ornaments, and the things one doesn’t use everyday. It’s called Suprashelf and made in Italy. It wasn’t expensive.
Flathead Johnny
you're located in Manila correct? we dont seem to have them here in the US and if we did I'm sure they would be expensive.....they look very nice
abstamaria
Manila
Yes, I'm in Manila, Johnny.
The system is lighter-weight version of the systems I usually see, but the load ratings are high. They have a bright finish, which makes them attractive. But they were less expensive than, for instance, the Whalen shelves.
Here is another section, which shows the mounting brackets.
Best,
Andy
Flathead Johnny
they look great, glad you got your hands on them
Best,
Andy
thomfr
The Netherlands
Best,
Andy
@Andy,
It is a system well known in the logistics world (warehousing on shelves) and is made (or at least the marketing name in Europe) by "Metalsistem"
(http://www.metalsistem.com/index.php?lang=en).
Thom
ps; no commercial contacts or interests
abstamaria
Manila
Thanks, all.
I didn't know that, Thom. A member from Italy sent me a PM, asking for the brand and website. I replied I didn't know. Now I do. I'll pass the information on to him.
Andy
p928sfan
Theodosia, MO
I think a couple others asked in here, but I'm wondering about ideas for a steel building storage ideas. I have a "red-steel" 24x28 building with the 4 main posts. On the lower half, I have stringers going across at the 8' level, but nothing below that. The walls are to long for a unistrut connection between the mains, so guessing something has to be run down from the stringer at say 8' intervals so I can connect them??
Or do I give up the hope of having storage mounted to the building and go with free standing containers like the stronghold, etc..
I do have racking systems across the short side - two rows on one side and one of the other, so I have a semi second floor on one side. I'll try to get some pics tomorrow and maybe that will help explain it better.
dittle fart around
You could always frame out the lower 8 feet with dimensional lumber.
RCStocker
Indiana, California, Australia
Self made cabinets build with extra supports and back. I have some full of wire and electric motors which are very heavy. Cabinets are easy to make and you can make them to fit every space you have.
You can make better ones for a shop than you can buy. If you don't have a table saw get on Craigs list and buy a good Delta or jet Contractor's saw. They are out ther for $150 and every one should own one. They are not the home versions. They are a very good saw.
A chop saw, router and basic tools is all you need to build any cabinet. Get an angles bit to put a back taper on the square doors and they will paint out and look great.
I have cabinets and work benches on my walls. I have a sign that says do not enter unless you intend to have an accident. LOL I have old signs where I have space. I hate tools, hoses, cords etc haning on my walls.
malodin
I made a shelf out of the step bumper after I put a roll pan on the truck.
is that a radioshack 4x4 i see on the shelf? the yellow version was my very first rc car....now i have 5 of them lol
rshadd
Doylestown, PA
I always thought it would be cool to hinge a matching tailgate from a pickup as a pulldown seat/work area.
That's an old Clodbuster R/C.
p928sfan
Theodosia, MO
Just to update with some pics.
Most pics are of the 24' side walls, last one of the back 28' wall.
And yes it's messy, ergo my storage questions.
