burleyfarm
That's nice looking, simple, and clean storage, Bsparks. Well done!
Agreed. Great idea. Mind if I copy
i am trying to stop that pile of random notes and stuff on my benches so i drilled some holes in clothespins and nailed them up to a shelf. hopefully having this stuff hanging in my face will make me do something about it.![]()
The ones from Priness Auto? I sell those for like 79 cents (with a client's logo). And honestly, anymore they ****. There is only one company that makes a decent one (One of my salespeople is out showing it to a client this very second). When they first came out they were great and then the competition started and the rush to make the cheapest was on. Now the magnets won't hold a single piece of paper up.
would be cool to figure out the marble thing
Simple and cheap loft storage above th garage door.
What did you use to suspend it from the ceiling?
Just waiting for that next temblor, eh?
Paint some lines on that floor, 1', 2', 3', 4' etc from that wall, so you can measure earthquake strength by how far stuff gets tossed.
Need pics and details about the alumatrailer in the overhead! How do you get it up there and how to support it?![]()
2x4s lag screwed to the walls around the perimeter. Supported the front by drilling all thread up into the attic space and thru other 2x4s spanning across the trusses.
Thanks for the response. I wonder if just the threaded rod would work for smaller supports which have no walls. I suppose it would have too much lateral movement then which could cause the rod to fatigue.
What's the advantage of having this over just putting the funnels on top of each other?My funnel drip recovery system.................
No reason to think it wouldnt
Yes, I'm in Manila, Johnny.
The system is lighter-weight version of the systems I usually see, but the load ratings are high. They have a bright finish, which makes them attractive. But they were less expensive than, for instance, the Whalen shelves.
Here is another section, which shows the mounting brackets.
Best,
Andy
Best,
Andy
I think a couple others asked in here, but I'm wondering about ideas for a steel building storage ideas. I have a "red-steel" 24x28 building with the 4 main posts. On the lower half, I have stringers going across at the 8' level, but nothing below that. The walls are to long for a unistrut connection between the mains, so guessing something has to be run down from the stringer at say 8' intervals so I can connect them??
Or do I give up the hope of having storage mounted to the building and go with free standing containers like the stronghold, etc..
I do have racking systems across the short side - two rows on one side and one of the other, so I have a semi second floor on one side. I'll try to get some pics tomorrow and maybe that will help explain it better.
You could always frame out the lower 8 feet with dimensional lumber.
I made a shelf out of the step bumper after I put a roll pan on the truck.
That's an old Clodbuster R/C.is that a radioshack 4x4 i see on the shelf? the yellow version was my very first rc car....now i have 5 of them lol
I always thought it would be cool to hinge a matching tailgate from a pickup as a pulldown seat/work area.
My dad has that exact same truck in yellow in our garage
