Need Source(s) for measuring small orifices
bobcat
Guys ... looking for a source where I can get some type of small wire "gauges" that I can use to measure orifices in brass air bleeds , idle feed restrictors etc in my carbs for fine tuning . Sizes will range from .024" to .080" .... also need a source for small drill bits to drill out the restrictors from say .067" to .071" etc . Sometimes only need to go 1 or 2 thous. and don`t want to spend a fortune .
Finally getting the carb close ..... I hope .
Thanks ,
Bob
AZ_Catskinner
Morenci, AZ
Easiest way to do it is with a set of acetylene tip cleaners and an 0-1 mike.
McMaster Carr has a nice wire gauge bit set for around $35.
Bruce Lancaster
Pin gauges are the way, cover every thousandth. Another way is shown in the OLD 1970's edition of the Q-Jet and Rochester book by Doug Roe...NOT the current edition which is much shorter.
Roe was a Rochester development engineer and shows how to use tapered jet reamers (available through Empi, VW souping places) to measure.
larry_g
oregon
Pin gages. Tip cleaners are abrasive and can open the hole unintentionally.
lg
no neat sig line
A_Pmech
IL
Pin gages will get you in the ballpark.
If you need closer measurements I'd use compressed air, a manometer and comparative measurement to a known standard orifice.
Rickster
SE PA
You mean like these?
CWP1616L
USA
Unless I'm missing something, all you need is a set of wire gage drill bits that go up to #80. Use the smooth end of the drill bit to measure the hole.
