BlackdogGS
I just applied the first coat of 1000 HS in my new 1,400 sf garage. Floors were 49 degrees (50 recommended) but I turned the heat up while applying. The next morning it was close to 70 degrees. I thined the first coat 20%. I used a 1/2" roller. It looks great for a first coat. You can see the fine cracks but I'm sure the second non thined coat will cover them. I do have 2 small areas where I got some bleed through from an un seen contaminate. I'll grind these areas out and re apply. The second and final coat will go on this weekend. It will have the shark tooth grit in it.
I used the white color and I'm so glad I did. I'll post pictures soon.
