Need ceiling fan options for 8ft ceiling height
Flash and Flare
Central, Wisconsin.
I have searched the net looking for a suitable ceiling fan for my shop without much luck.
My trouble is that I only have 8ft ceilings so clearance and safety is an issue.
In the past I been using a high powered 18in floor fan to circulate air, but its noisy and stirs up alot of dust.
My shop is 24x24
I got 2 separate 110v 15amp lines run to my center junction box in the ceiling so I would like to have a fan with a light or lights
My criteria.
As low profile as physically possible
Quiet
Reversible blade direction
Light/s
Variable speed, preset or with a POT.
Don't want anything that looks like it belongs in the dinning room or family room. The less frills and more basic the better.
Anyone got any ideas or links to products ?
Thanks
F&F
F
Flash and Flare
Central, Wisconsin.
Ksullivan
Campbell, NY 14821
What about an exhaust fan that would still circulate air in the garage and wouldn't compromise your headroom, you could vent to outside and I have seen vent fans that move 180 CFM. Hope this helps.
hardhat
But a cheap hugger celing fan and spray paint it with your color of choice maybe flat white, gray, black,ect to give it an industrial look. I havent seen an industrial hugger fan so youll have to go with an residential indoor one. There are some cool wall mount ones available as well.
GirchyGirchy
Central Indiana
I put a flush-mount ceiling fan in our master bedroom, which has 8' ceilings. It's a Hunter Low Pro III, the short blade model. They have 52" versions as well, with or without lights. Seems decently made. Mine needs balancing but I don't run it very fast.
For speed control, I use my favorite wall switch - it's a 3-speed fan controller and light switch with dimmer, in a single gang size. One side switch does the fan, the other does the light dimming, and the toggle turns the light on/off:
http://www.menards.com/main/electri...r-and-fan-control-toggle/p-1359603-c-6322.htm
F
Flash and Flare
Central, Wisconsin.
Thanks everyone, I am pretty sure I am gonna have to go with a residential unit minus the lighting assembly (unless I can find a high output LED to retro onto it)
I like the idea of spray painting it, I think a natural cast iron look would be cool.
F&F
