Cool Plier/cutter set
e-tek
Saskatoon, SK
I needed a set of end cutters and found this nice set with chanegable heads. Of course I have all the heads in other pliers, but the price ($19.99) was right. Very high quality, good metal, lifetime warranty.
Keson HLS1130 Features:
• Unique multi-use tool is ideal for the professional or do-it-yourselfer.
• Patented design allows for quick changing of 3 different plier heads in a matter of seconds.
• Handles are spring loaded for easy one handed operation.
• Large compound handles provide 50% more gripping and cutting power.
• Heads snap on and off easily by hand, no tools required.
• 1/3 lighter than regular pliers.
• 3 cutting heads: linesman, sidecutter, & wire cutter nose, plus regular pliers and ring clip pliers
• One HLP replaces 5 conventional tools
Anyone heard of Keson before?
greasemonkey44
memphis
i havent but i like the look of the snap ring head
and it looks like it has the high leverage like crescent diacs
SGKent
Citrus Heights CA
I bought some snap ring pliers that were kind of the same. They sit cause they are more a gimmick than a real tool. Get good quality of the real thing and you will never look back.
jamesc
Ontario Canada
I saw those in a store recently, I was not interested. I would rather have 5 different pairs. even if it is 5 times the cost.
JASTECH
Gering, NE
Two pair of the 5-head plier set $35.00. The Keson company started in the USA in the late 1960's supplying shops I think, others can correct me as needed as my memory isn't what it use to be. But please let us know fit, finish, quality of steel and handyness to functionality.
Thanks, JASTECH & Son
raskal
British Columbia
just got an email from PA, that plier/cutter set is on sale (online only) for $9 + $7.30 shipping (today only)
not a great price for sure, but if you wanted a second set, cheaper than driving to the store
J.A. Gates
I picked up a set of these at a garage sale yesterday. I immediately tried them out when I got home. The side cutters snipped a piece off of a stainless steel stiffener from an old winshield wiper blade no problem. Changing the heads is quick and easy. I will quite likely get the end cutting nipper and straight needle nose head, plus the tool holster. I think they will be a valuable addition to the toolbox for this old reitred A&P mechanic.
As for the Shopsmith, I have a Mark 5, with jointer and scroll saw attachments. I love the thing! I would like to find a bandsaw attachment. It takes less than five minutes to convert from drill press to table saw, or from table saw to lathe. I have used the drill press to drill 5/8 holes in 3/16 mild steel, and I have used the table saw to cut .060 6061-T6 aluminum.
J.A. Gates
I contacted Keson about getting accessories for the HLS-1130 plier set. They quit making them several years ago.
Too bad. I rather like the set I got!
If anybody has heads for one of these, or the complete set (all heads and holster), I would be interested in buying them.
Ray-CA
San Diego CA
Like all tools, it depends on the operator. They take time to set up and change from tool to tool and, yes they have limitations. You're not going to cut full sheets of plywood very easily but I've seen some really incredible work come from very small shops that used the ShopSmith.
Ray
rlitman
Long Island
Don't think I'd like having to have the handles so far apart to get the jaws fully open.
That's the tradeoff of a compound action. But you get increased leverage.
I don't like compound action pliers for everyday use, but they do come in handy when I need some extra crushing power.
Zapp Branigan
That'd be good for a road box where space is limited, but more aggravation than they're worth in the shop.
