Metalworking saw
mortimersnerd
I've got a decent amount of metalworking planned over the next year (rock sliders for my '71 Bronco, possibly a roll cage, some railings for my yard, etc). All of it can be cut with a grinder, but I'm wondering if you guys have suggestions for something that will cut faster and more accurately. Thought about a chop saw or bandsaw. Any ideas?
Warrenator
Newberg, OR
I had the same dilemma, safety was my justification. (I sliced a big chunk out of my leg using a grinder, requiring a trip to the emergency room.) Plus the grinder was hard to make accurate cuts on tubing. I bought a powermatic 143 bandsaw used on ebay for $800. What a nice piece of equipment. Slow speed for metal, high speed for wood, rigid frame so you can tighten the bands sufficiently, tilting table, miter slot so if I want I can make a compund cut (tilt the table and use a miter guide in the slot). Or just draw lines on your piece of metal plate and cut to the line. I thought long and hard about getting just a horizontal metal cutting bandsaw but decided the versatility of the vertical bandsaw was too good to pass up.
I really like this bandsaw. I thought about moving my bed out to the garage to sleep next to it.
drb007
WI
In general, power hacksaws will cut more accurately than the bandsaw. The bandsaw tends to wander a bit if the settings are off or the saw is worn. The hacksaw is a bit slower, but the blades are much easier to change, and less expensive. They sure are fun to watch run!
My dad has a Keller with the oil well, and I have a Jefferson 601. Google and YouTube have lots of info on them. They also take less floor space. Cuts everything I have to do...
gmwelder86
Oakdale , ca
Depending how much you want to spend a portaband sounds just like what you need. Versatile, relatively cheap and can use pretty much anywhere.
drb007
WI
I have a chop saw as well, and used it all the time until I got the power hack saw. The chop saw is LOUD and messy. And again, accuracy is an issue...just sayin...
signcrafter
A chop saw is different than a carbide thipped metal cutting saw. A dry cut saw cuts clean and almost burr free.
crewchief888
NW indiana
all depends on how deep your pockets are...
and how much "space" you have to store equipment.
i've cut lots of tubing with a HF (& it's replacement, a ridgid) abrasive chop saw in my 19x22 garage,
and it's portable if i need to do some work away from the garage.
:beer:
justanengineer
Motor City
I would suggest finding a used horizontal bandsaw from Carolina or one of the other good ol' US saw makers. Chop saws and cold saws are quick, but somewhat size limited. I also wouldnt wanna buy one used as they tend to be abused. If youve got a bit of room, you could also find a good vertical saw like John's Do-All. If you have all day to get the job done and dont care about things like parts support, but are on a $25 budget you can buy a power hack.
2mJps
north central Mo
It sounds like you are new to metal working. Do yourself a big favor and by a bandsaw. Stay away from things that kill you slowly by throwing clouds of junk in the air you breath Like a chop saw.
muibubbles
nj
damnit. i just saw a video on the femi ng120............. I was looking to buy an Evolution rage2 chop saw around black friday but this thing is tempting!!!
hmm evolution rage 2 for $300 or the Femi 782xlh for $500.............../
edit: jut noticed there is quiet the difference in the ng120 and 782xl.. also the 120 is double the 782 =(
machine_punk
Napa Valley, California
There are so many answers to that question...but based on the sorts of things you anticipate cutting, I'd recommend a band saw...I like the Milwaukee, portable, deep cut, variable speed model (You can get them for around $300 new, or a little less used. I recommend the new, simply because of design updates...they have true variable speed, instead of a choice of two speeds.
I put a bandsaw 'table' on mine and often use it like a vertical bandsaw, with a custom 3/4" plywood bracket I built for it...
View media item 24133
View media item 24131
View media item 24132
View media item 16151
Kev
shoot summ
femi bandsaw
http://www.hemsaw.com/bandsaw/utilitybandsawo.htm
Been looking at these for a while, just need a job to justify it.
Nice. I never heard about them . Do you know of anyone that has one ?
The Manufacturer/Distributor is near me, first saw this saw at the Fair a couple of years ago. It is VERY impressive. That said it is also very expensive. I WANT one, but realistically I don't NEED one. My Rage saw does just fine.
The big advantage I see of the Femi over the Rage is there are no "chips" that get EVERYWHERE.
