Board & Batten Vertical Siding
LB62
NE PA
Has anyone used board & batten vertical siding on their garage? If so can you post some pics for me? Also did you use vinyl, wood or fiber cement? We have a craftsman style home and looking for our new 28’x38’ garage to match.
ahrbrz
Is this what you have in mind? Cedar siding.
Cheers,
Bruce
Zeke
I've used 1 x 12 cedar for this. I ripped my own batts. You need horizontal blocking on 24" centers. Plywood alone is not enough backing. Leave a 1/4 to half an inch between and nail the batts through the gap.
p_mori7
Montreal, QC., Canada
I did mine with 1x8 rough sawn hemlock boards, had them milled to get a reverse board / batten look.
+1 on the horizontal 1x3 strapping.
see the link in my sig.
L
LB62
NE PA
Cheers,
Bruce
I was looking for the main walls to be a board & batten and was looking to do a horizontal in my gable. I like that look. Is that a T1 11 cedar siding? Pic of our rancher pre and post change attached.
Doug B
Schroon Lake, NY
I used 12" pine B&B on mine,but the goal was for it to look like a barn...
ahrbrz
If you are referring to plywood; no. Cedar planks that are 5 1/2" wide.
Cheers,
Bruce
TheShrine
Texas Hill Country
100% Hardiboard...
PAToyota
South Central Pennsylvania, USA
Like "The Shrine" shows. True board and batten siding - with individual boards - has entirely too many potential leaks. Do a full sheet of cement fiber siding and apply the battens over it if you want the look.
BRIANBB
Katy Texas
Yes, 4x8 sheets of HardieBoard and put the battens on top. WAY less work and more weather resistant.
BWS
Mnts of Va
Though its usually not thought of as ideal?......we have white Oak B&B.Its done pretty darn good.Though the house is mainly brick,we did side certain sections.
But reason for post was.....for me,you can't really have a discussion on B&B(board/batten) without at least mentioning AJ Downing.While he may not be all that "great" of an architect?......his promotion of B&B and country design was instrumental in shaping a lot of the "thoughts" we have today on the subject.
http://books.google.com/books?id=5_7wjH26cVkC&source=gbs_book_other_versions
TheShrine
Texas Hill Country
The OP asked specifically for "board & batten vertical siding"...that's what The Shrine has. When done correctly, with the right craftsman, B & B is a proven method to clad a building. Using the excuse of potential leaks is tantamount to claiming shingles on a roof are potential leaks and you shouldn't use them either. :willy_nil
Cheap and easy to get a "look" is an option. It was not an option for The Shrine.
L
LB62
NE PA
Thanks! You just sold me on the look. I think it will fit my home and the neighbors want get as mad about the size... lol.
Norcal
My shop is board & bat siding, but was done w/ plain rough sawn siding, & the bats were made from 1X12X16 #3 cedar ripped into 3" batts. Here is a photo during a repaint.
PCO6
Newmarket, Ontario
My shed is board and batten ..."sort of". I cheaped out by using construction grade plywood and 1"x2" strapping. I built it in 1992 and it has held up well.
Exit 61
So Cal / Oldtown Idaho
This years projects all western red cedar 11 1/2" @ .20 per board ft. with a 15lb felt under layment and 3" bats.
PAToyota
Sorry, I didn't look closely enough to see that you used individual boards - saw the HardiBoard comment and assumed that you were using the sheet goods.
I think the part about "when done correctly, with the right craftsman" is the key, though. Not enough of either with today's contractors...
bob15
Northeasten, CT
The back of my garage has reverse B&B, I prefer that look over seeing he batten all the time. Another option is ship lapping the wood, which I will be doing next year for the front of my garage, using rough cut, 1x8 Eastern White Pine boards. Right now the wood is air drying/shrinking. Ship lapping will look like reverse B&B when finished.
bob
thdewey
Gastonia, NC
Boy these are some beautiful shops! I love board and Batten siding. If I ever build again it will be done this way. Thanks everyone for sharing.
G-force
Oregon
I've been wanting to do a rustic B&B siding on my barn for years. It like it to have a weathered look when done and raw rough wood. Reclaimed would be great but terribly expensive. Plus mine is a pole barn and I imagine if I hung B&B I would need to stick frame it for the extra weight. Ideally I'd want it to be finished something like this...
RickP
Annapolis, MD
What is the maintenance on using a cedar siding?
If you use a sealer or stain, it needs to be recoated every so often - depends on your local weather. Our former house had solid color stain while a neighbor's just let their cedar turn grey naturally. Their house was a lot less work... We had to re-stain every 3-5 years.
