I was looking for the main walls to be a board & batten and was looking to do a horizontal in my gable. I like that look. Is that a T1 11 cedar siding? Pic of our rancher pre and post change attached.Is this what you have in mind? Cedar siding.
Cheers,
Bruce
Like "The Shrine" shows. True board and batten siding - with individual boards - has entirely too many potential leaks. Do a full sheet of cement fiber siding and apply the battens over it if you want the look.
The OP asked specifically for "board & batten vertical siding"...that's what The Shrine has. When done correctly, with the right craftsman, B & B is a proven method to clad a building. Using the excuse of potential leaks is tantamount to claiming shingles on a roof are potential leaks and you shouldn't use them either.
Cheap and easy to get a "look" is an option. It was not an option for The Shrine.
What is the maintenance on using a cedar siding?
