Caps for air tool quick connect fittings
joe_padavano
Northern VA
I'm looking for a source for rubber or plastic caps for the quick connect fittings on my air tools. Here in Northern VA, we have mud daubers that like to build their mud nests inside any pipe or opening. I regularly have to disassemble and clean out the quick connect fittings on my air tools because of this (and god help you if you forget and blow all that mud and bug eggs into your air tool... :scared:). And yes, the little #@$&@# bugs even do this to air tools stored inside the drawers of my tool box - not to mention pieces of brake tubing and vacuum hose.
Yeah, I can easily get vacuum caps and push them over the fittings, but I'm looking for something with a molded-in tether, like the caps used on some brake bleeder fittings, so I don't continually lose the caps. Thanks in advance for any help.
Mr.Nutcase
USA
1. condoms... and reusable zip ties
2. cooking wrap
Givl Reggin
Hawaii, USA
Is this what you're looking for (colored in red)?
I bought a bunch of them for my air tools and they work very well. They're made from a flexible rubber and fit tightly on the end of the air connector. Only problem is you have to take the air connector off to put them on because the rubber doesn't stretch enough to allow it to just slip over.
You can purchase them thought their parts department... http://servicenet.portercable.com/Parts/Detail/216925
J
joe_padavano
Northern VA
Awesome, thanks. I'll also check HF (thanks for that suggestion also). I looked at cap vendors like Caplugs and couldn't find anything that was the correct size.
Provincial
Near Salem, OR
Low tech solution: Leave a tool attached to the end of the hose at all times. Store spare tools on a wood block with finish nails sticking up and slide the coupler over the nail. With the opening occupied, no mud daubers!
J
joe_padavano
Northern VA
Yeah, I'm skeptical of my 18" air board sander standing on end over a finish nail.
JimDon
Erasers for the end of a pencil , the kind you buy after the regular eraser wears down
eyeball
3D Printer and some ninja flex and you could make what ever you want/need.
https://ninjatek.com/products/filaments/ninjaflex/
I am always looking for a job around the house that will require (justify) me to buy a new tool but... buying a $50 spool for the 3D printer would equate to about $10 per cap for my small arsenal of pneumatics.
I think I will go with the earplug idea.
gte718p
A valid point, but then you have a new tool and a new stock. Who knows what you will get yourself into?
I bought my small printer on a whim. It was cheap. I'm amazed at how useful it has been.
Sugarfryz
Honestly thought this was going to be a thread worrying about a little dirt getting in. I can’t imagine realizing I have wasps in my air tools. I hate them.
