I created a tool road repair kit that is contained in a duffel bag, a Craftsman 12" tool bag, a Craftsman hand tool carrier, and 2 cardboard boxes. Here is the list:
duffel bag
- 1 $15 Mack Trucks (Chinese) 2 ton baby jack
- 1 OTC 24" curved pry bar
- 1 wood block for jack
- pair of gel knee pads
- 1/2" drive beam torque wrench
- Streamlight Survivor 3 watt Luxeon single bulb flashlight
- OEM brand (AutoZone) plastic push pin removal tool
- Lisle model# 23000 hose pincher tool
- Tool Aid model# 13820 hose puller tool set
- Craftsman miniature plier (Chinese)
- Channlellock model# 440, 12 inch tongue and groove plier
- Knipex linesman plier, Autoloader screwdriver Autoloader 30 piece screwdriver bit set; Husky multi-bit, mini screwdriver; tire pressure air gauge, Craftsman extendable magnetic retriever; various Irwin Vise-Grip locking pliers
- J.H. Williams 8" adjustable wrench
- super short sockets and crowfoot wrenches from a KD model# 3414 serpentine belt tool set
- Craftsman 3/8" drive universal joint
- Craftsman 5 piece, model# 42170, metric (7,8,9,10,12,13,14,15,19,21mm) ratcheting dogbone wrenches
- Gearwrench 2 piece, metric (13,14,15,17mm) ratcheting S-shaped wrenches
- Ko-ken 3/8" drive, metric (8,10,11,12,13,14,17,19) mid-depth socket set on a rail
- Ko-ken 3/8" drive, flexible shaft socket extension
- 1 long, untwisted coat hanger
- 1 claw type, flexible parts retriever
- 1 15" long, 1/2" drive, flex head breaker bar
- 1 1/4" drive, Gearwrench socket and ratchet set in blow-mold case
- 1 3/8" drive, Gearwrench socket and ratchet set in blow-mold case
- 1 Toptul metric (10-19mm) Dynamic short combination wrench set
- 1 Blackhawk metric (10-19mm) flare nut wrench set
- 1 Gearwrench "Double X" straight and curved nose long reach plier set (model#'s 82005 and 82006 in set)
- 1 Wiss metal cutting, multi-material scissors
- 1 1/2" drive, 3/4" deep socket for lugnuts
- 1 3/8" drive, 5/8" spark plug socket
- 1 Nupla stubby dead blow hammer; model# 10714 "Thumper" handless hammer
- 1 brass hammer
- safety glasses
- Irwin retractable razor knife
- set of brass and stainless steel brushes
- 1/4" and 3/8" drive socket drive adapters
- 1 15" inch long iron pipe for leverage
cardboard box
- pair of in-ear, foam ear plugs
- dust mask
- car repair manual
- 1 roll of shop towels
- package of nitrile gloves
- zip-lock bag containing zip ties, duct tape, electrical tape, rubber hose repair tape, home repair tape that binds to itself; IPCOL P-80 Thix Temporary Rubber Lubricant Gel to ease installation of new rubber hoses (free samples can be ordered here:
http://www.ipcol.com/shopcontent.asp?type=requestsample; mention you are associated with a business; IPCOL does not mail out samples or sell products to individuals); long double-headed cotton swabs for electronic applications (used to apply IPCOL to the inside of a rubber hose)
- ratcheting hose cutter
- Craftsman 3/8" drive external Torx socket set on plastic rail
- Craftsman 3/8" drive, 2 piece, hex bit socket set on plastic rail
- Kobalt 3/8" drive, 2 piece, internal Torx bit socket set on plastic rail
- automotive fuse set, tire valve caps; batteries for garage opener and keyless entry remote
cardboard box 2
- 1 gallon of Peak 50/50 "ready to use" antifreeze
- 1 quart of oil
- 1 Kroil rust penetrant spray
- 1 CRC electronic contact cleaner spray
- 1 bottle of 91% rubbing alcohol
loose in trunk
- Toptul metric (10-24mm), standard length, combination wrench set in metal case
- Coleman 12 volt, single halogen bulb portable light (powered by battery booster)
- 1 K&K Jump-N-Carry battery booster
- 1 BonAire 12 volt, mini electric air compressor kit (powered by battery booster)
- plastic bag containing old radiator and serpentine belt hoses from current vehicles
- first aid kit
- cloth blanket
- large plastic sheet
Dave
