I finally got this done and it turned out really good. The slab is about 11 years old and it had a sealer on it. Also my painter sprayed the walls and I had a ton of over spray on the floor. I ended up renting a diamond grinder and to be honest I almost over-ground the floor trying to get the sealer and over spray off.
I taped up my shoes so I would not destroy them.
I went with Legacy's epoxy primer, and I will never do another floor without it. I didn't have one single bubble from out gassing. Temps were probably about perfect at 65 degrees.
Next was the base coat which was dark grey in color. The chips I chose were the grey/blue/white/black. I actually divided the slab into 4 sections, but to be honest I had plenty of working time with each batch. I probably could have done the whole thing at once, but I was afraid it would kick fast. The chips seem to land evenly and I went for a mild broadcast. The paint pal seem to work good to aid in carry the chips around.
The top coat is the urethane clear. It was easy to spread, but really has an odor. I was afraid to put it on too thick and actually only used a gallon on a 24x24 slab. It has been down for about a month and still looks great.
I finally got the stripes on the wall and the block wall painted. I"m very satisfied with the results.
I highly recommend Legacy Industrial for your next epoxy floor project.
Thanks,
Russ
Thanks,
Russ
