volunteers
My work bench is so smooth and neat that I really don't want to drill four holes to mount the vise. Where do you guys put the vise on at your garage? Any cheap vise stand solutions? Thanks
I only have one work bench at garage and sometimes I have to use the entire bench for my work. If the vise is mounted on the corner, it is inconvenient for me. That's reason I am looking for another solution.
I'm assuming you don't weld since you have only one bench and you say it is smooth and neat so my advise is to buy a welder, take up welding, make a welding table and make it heavy as $h!t, then bolt your vise to it. You will have a nice, kitchen-counter bench for your clean stuff and a manly, hit-it, beat-it, weld-it, heat-it bench for your hairy chested stuff. It makes for a more rounded out garage too.
Kind of a one size fits all answer but if you have room just make the second bench.
jack olsen,that whole set up is perdy,table,boxes,and all,i may have to copy,can you post pics of the rest of your shop
and only do bench work.... clean bench work.if i had that garage i would wear a set of scrubs and surgical mask,gloves and gown when i work on stuff
Drill the holes and move on. Nothing works like a properly mounted vise. Is your garage a real garage or a toy room?
You can attach a receiver hitch underneath the bench, and then make a base with square tubing to go in it.
But honestly, you should just bolt it to the bench. Get some large wing nuts for down below if you want to make it removable.
That garage is so nice I would never want to work on anything in it. I'd just sit around in it and look at how nice it is.
I hate the Jack Olsen. LOLOLOLOL
Just when I run out of engineeering ideas the boy usurps my keen sense of DIY can-do attitude. Dammit.
That is an AWESOME idea.
Thank you and muchos gracias..
This is ridiculous, Use your freaking workbench, its not your kitchen counter. Like is this even serious? Its called a "bench" vise for a reason.
Now we dont just have tool polishers on the forum, we also have bench polishers.
I guess this one will work:
http://www.harborfreight.com/bench-grinder-stand-42986.html
