Where do you keep your crowsfeet?
adamsredlines
CenTex
I'm conflicted...where do you keep yours and why?
Wrench drawer?
Socket drawer?
Specialty socket drawer?
Somewhere else?
I'm thinking with specialty socket/drive stuff...but am curious how you guys have them organized.
rshadd
Doylestown, PA
Mine are in socket racks, so they're in with the sockets.
Super Sport
West Michigan
I don't have room for them in my wrench or socket drawers, so they're in some obscure drawer near the bottom with other odds and ends waiting to find a use.
O_M_Jeep
South central Wyoming
^^^^^ I like that idea, but if you use them regularly it seems it would be a PITA getting the one you need, I use mine not quite daily but several times a week, I like being able to get the 5/8 or 14mm out of the mix easily.
thightower
oklahoma
Keep mine in my socket drawer. I put mine according to drive size. 3/8 has its own drawer and 1/2 has its own drawer.
JASTECH
Gering, NE
Connected to my ankles. There are some in top section of my overloaded service cart, then a set at the foot of my bed (yes for real), others here have seen pics.
Packard V8
Spokane, WA
X2 on this one in the socket drawer. Since they'll require a driver, putting them in with the wrenches just requires opening two drawers.
jack vines
dudutzu905
this is something I found in a different thread, looks like you should be able to just pick one without taking them all out
they work great. my dad and I both use them and have for years
they come apart in the middle allowing you to access any crowsfoot you want
bob
View media item 2022
PCO6
Newmarket, Ontario
First, I can't take credit for the idea. I saw it on GJ! :thumbup:
It's actually very easy to use. Just pull the pin at the end closest to the one you need and slide a few off until you get the one you want. The fit is fairly loose and they come off and go back on very easily.
crewchief888
NW indiana
mine are in the top of my box with all the rest of my 3/8" & 1/2" dr sockets.
smallest is 13/16" flare nut, the rest are open end 7/8"- 1 1/4", 3/8" dr,
1 1/4" open end, 1 1/2" flare nut, both 1/2" dr.
bought them all over a 20 year time span, as i needed them.
:beer:
GRX
MD
In lieu of on their leg ends, I keep my crow's feet in the drawer with my chisels, punches, and pry bars.
dirtmister16
wisconsin
generally on a crow.
but in this case well they live with my other drive tools in the drawer. but i have no holder i will have to find one that i like.
bgott
Houston, TX.
Actually...I don't understand how they work and where they would be used...anyone?
They mainly sit in the drawer and collect dust, but, when you need one, you really, really need it! I used mine last week replacing a power steering line. You stick an extension in the drive hole and you can snake it down lines and past obstructions where you can't fit a wrench.
ihateminimumwage
Usually on the side of my socket drawer, but my box is at the shop and my crows foots are at home currently, but the magnets on the rail make it easy to move wherever it needs to go.
alex71
SE Florida
I keep mine in one of my wrench drawers. I stack them on a 3/4" square bar with a presto pin in each end.
i use the exact same setup. just need a bit of keystock, or square tube if you can find it in 3/8", and a couple of hairpins.
gatewaysysop
Arizona
In the blow molded case they came in from NAPA.
I do something similar, I got the flare nut crows foot sets in standard and metric during one of those half-off Craftsman Club sales they used to have some years ago. I just keep them in the plastic packaging they came in, cheap but effective. :thumbup:
Jarhead0408
Who knows?
Same here^^^ I don't use mine all that often so I just keep them in the blow molded case. I've got just enough spare room in my metric wrench drawer to fit the cases in.
SS5150
NE IL
I got mine about 4-5 yrs ago from Matco during a BOGO deal (metric & SAE), both sets came in a blow molded case. After using up a ton of toolbox space I chucked the cases and stuck each set on socket rail. I keep them with the rest of my sockets.
hofferwood
DownRiver Michigan
Maybe here?
If so:thumbup:
shoturtle
Frankfurt AM
This is my way of handling my metric crowfeet. They stand up quite well in the drawer.
