Machine shop layout help
383 240z
Findley Twp. Allegheny Co.
For you guys with mills and lathes in the home shop. What do you have near each machine? I'm organizing my shop now. What I really didn't like about where I have the mill now is that I have no good way of keeping the tools I need close at hand. Right now I have a roll a way tool chest with my machinist chest on it and my t-nut hold downs hanging on the wall.
I don't have a lot of tooling for this, just the collets, a bunch of end mills, a drawer full of layout tools, mics and calipers, and indicators.
Where I plan on putting the mill is backed against a wall, under 4, 8ft t-8 lights. I have about 14' of open wall on each side of it. I'm considering building a floor mounted chest of drawers. however to have it within arms reach, it would have to be very low, if I lowered the knee much. Directly behind the mill is a double door.
Do you guys keep this stuff close? Keith
sberry
Brethren, Michigan
Things dont have to live the first place they land, dont be scared to get a different view and loacate things where they belong vs where they are.
1953mercury
Steamboat Springs CO
I've attached a lot of commonly used stuff directly to the mill body(brigeport), i.e. clamps, r-8 collets, etc.. The rest I have in top and bottom Craftsman boxes close by. Mike
383 240z
Yea, I have a half assed, make do set up now, and it *****. Hence the re-do in the new space. Only thing is once I build the shelving and storage, I'm pretty much stuck with it for some time. So I'm hoping to get a pretty good set up right out of the box. So any photos you guys have and are willing to post would be great. Keith
Steevo
43.49600, -112.04300
I have only one toolbox dedicated to the storage of machine tooling.
Therefore, it has to live nearer to only one of my machines.
I currently have it stored next to my lathe, because that is where I have room for it.
If I had unlimited space and budget, I'd have lathe-specific tooling near the lathe and mill-specific tooling near the mill, and maybe even drill-press-specific tooling near that ( I don't currently have a drill press in my shop).
Bib Overalls
Jonesboro, Arkansas
I put my mill in a corner. A lathe goes best along a wall with access the left so you can pass lengths of tube and round stock through the spindle head.
I have one Lista cabinet dedicated to mill and lathe tooling. I keep it next to the mill because that is the only space available.
Good lighting is important. My mill, drill press, and lathe are under my 8' deep storage loft. I have a 24' run of T8 fixtures underneath. They really light things up!
justanengineer
Motor City
Youve got very good timing as I too am in the process of reorganizing and my machine tooling is the last of the "clutter." Currently my Bport is also in a corner with a bench just to the left followed by the shaper and my big box which has the measuring tools in it. On the right is a space my lathe is going once I finally retrieve it from NY, but currently holding that space is a Cman top box that contains a portion of my collection of drills, reamers, and taps. Unfortunately, the rotab, dividing head, and vise are living on the floor beneath the table, the surface plate is hogging bench space, and a few other odds and ends are stashed away at the moment.
I'm in the design stage right now, but soon will be building a smaller (width-wise) version of the Moore bench shown below customized to house the larger mill specific items and clean things up a bit. Our in-house toolmakers at work have an original one of them in beautiful condition, albeit without the "smaller" Moore cabinet that paired with but looked nothing like it, and Ive definitely been jealous for quite awhile. On mine, I want a drawer that is a built-in collet rack, a workbench top that lifts out to reveal a surface plate, and quite a few other lil "nice-ities."
http://www.practicalmachinist.com/v...e-moore-mahogany-tool-cabinet-fs-john-022.jpg
kazlx
Tustin, CA
I just have a vintage rolling tool cart that I use for tooling for my lathe. Just got the mill and will try to find something similar. My lathe is on a base that has storage area in it where I keep the tooling I don't use as much, extra chucks, face plate, rests, collets, etc. Here is something similar my buddy did that he plans on keeping next to his mill he just bought. He is going to cut a butcher block top for it.
BWS
Mnts of Va
Built a 11g shelf that attatches to lathes backsplash.Its in two sections.The first has holes bored in to recieve chucks tailstocks N such.The other section is a pan of sorts....in which a bunch of cutting tools are stored.The two sections are seperated by a space that allows files to slide into.
Measuring equip for lathe is in a huge custom made rollaround,parked at headstock end.Its sporting a surface plate on top.
The mill is bass akwards from most....instead of an "inside" corner,ours is on an outside corner.This arrangement allows two bxs to be neatly drawn right up to mill.They're flanking it.One is std bx...the top never gets closed.Surface gages,endmills,layout chit is in the top.All the other stuff is below.
The other mill cabmet is a custom job.Its mission is to hold the 15" RT.The way its setup...it interfaces with mill table(pull out its one drwr....mill table fits in this opening)allowing easy on/off.The bttm of this cabmet houses a sm air comp that drives a cpl air vises.
A tall gym locker is used for lubes.
2mJps
north central Mo
My shop was 30x30. I have 3 lathes 2 mills a shaper and 2 drillpress. The most used lathe had a rack on the wall behind it for most used stuff all the other stuff were in cabnets. It worked good because i didnt have to go around looking for stuff it was in a cabnet.I would place machines so you can have stuff hangover them like a long shaft in a lathe
Matt018
At work we just have a heavy duty lista, type cabinet with the tooling for that machine.
Falcon67
Merkel, TX
I put my machines on wheels. The lathe (9x20 HF model) is on a heavy duty Seville cart that stores all the lathe and most of the mill items.
The mill is also on wheels, but mills work better in a corner (IMHO) which lets the table move and uses a little less floor space. It's in the back corner:
It has a air drop right at the machine and the clamp kit on the wall behind it. I intend to put some drawers in the base of the mill table one of these days. The table is shop made. I have a bench in between the machines for additional working room.
383 240z
To put this in context, the lathe is on a wall with about 6' of free wall on the head stock side. I don't have a lot of tooling for the lathe. I keep most of it on pegboard on the wall behind it. the rest of it is in a small 3 drawer chest that's bolted to the wall. Lathe size is 13x40. The mill is a Cincinatti Toolmaster. 9x42. How are you guys mounting tools to your mill? Keith
Zeke
I think a rolling cart with a chest on top or a full on rolling box is the best because ideally you want the tooling, etc right behind you. Not on the wall where you have to reach over or around your machine. That just seems safer to me. And less steps to your stuff.
When not machining, roll your tools back into a storage spot.
saabman
Sebago Lake, Maine
I put the things that are not high precission on wheeled stands (vertical bandsaw, horizontal saw, etc). CNC Mill, lathe, and big drill press have permanent locations around the perimeter of my small home shop.
benjamintmiller
IA
I don't think it's been mentioned yet, but you want to keep your welding and grinding FAR away from your machine tools if you can help it.
I've organized my shop into several general areas:
- Car (in the winter)
- Parts washer and sandblasting cabinet
- Welding and grinding
- Machining (mill and lathe)
The surface grinder is near the machine tools, but directs its grit in the other direction.
383 240z
Oh yeah, I have a wall between the machine shop area, and the main shop area. Only real tools in there are the mill, lathe, press, parts washer, work bench, and drafting desk (I really need to learn CAD and SolidWorks) a PC and a radio. All the grinding and welding tools are in the main shop. I don't even plan on haveing the horizontal band saw in the machine shop area. Keith
Fueler
Urbana, IL
Concerning the mill. I have done the wall thing, I have done the corner thing.
Both will get you in trouble some day. If you have the floor space, somewhere in open space and/or with stuff that can be moved away from it works better.
It's amazing how many times I had to hang something off the back of the table and swing the head accordingly. I even rotated the head 180 to do something with a large engine block one day. Just sayin.
Dan Tootle
I am looking for assistance with establishing a design for a vocational/technical agriculture college machine shop. The college is located on the north coast of Haiti and is in the process of being revitalized as an agriculture training and regional community agriculture operations resource center. The machine shop I have in mind is one where farm equipment (tractors and implements), diesel engines (farm tractors and diesel/electric generators), farm machinery (irrigation wells, pumps, hand farming tools, etc.) can be maintained and repaired. This would include welding, cutting, metal forming, etc. that would be common to a farm or ranch operation.
The machine shop is expected to act as an education asset to teach college students in farm machinery and equipment maintenance and repair, and to also be a regional resource center where farmers and agriculture operators in the immediate area can come to receive machine shop support for their equipment. The set up should not be elaborate or CNC/computer supported as this area is one where the use of farm mechanisms is still fairly new. So it needs to be both effective and simple in approach.
My involvement is as the Program Manager for the college revitalization, and having grown up as the son and grandson of farmers in the Central Valley of California where we always had a small machine shop for our farm equipment support work. The purpose of having a machine shop within the college curriculum is to ensure that our graduates have the capability to support traditional (non-machinery) and current agriculture operations that are starting to introduce more machinery-assisted farming operations within this area, while also providing a resource for other agriculture operators to use as there are limited resources for this type of support where the college is located.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Dan Tootle.......Welcome to Garage Journal. If you would, could you put your location in your profile? It does help with some questions although not this one.
I'll have to find the pic of our Toolroom. I had the task of laying it out and to still keep things so we had the best efficiency for the size of the room. Our shop wanted things where they were close to proximity to eliminate wasted steps. Desk to mill, to lathe, to perishable tooling, to raw stock. For the size of our room, things were laid out to where one could actually run two or three machines at a time. CNC machinery of course with one non-CNC machine also being used.
As soon as I find the pic, I'll post it up.
Dennis Leigh Henry
South Central, IN USA
Dan Tootle.. welcome to the GJ..hope you find what your looking for..
I had an entire 3 credit hour course in how to plan for the industrial arts laboratory, everything from equipment purchase, tool sources, supply sources, paint, lighting, safety, chemical handling, emergencies, etc... The text we used is in the picts... Its a bit rudimentary, but good at getting the basics mapped out, with plenty of school shop pictures of the super 6 of Industrial Arts (woods, metals, graphic arts, drafting, electricity, power/auto mechanics) and the new 4 (construction, manufacturing, communications, power), as well as specialty labs for voc ed.. Stamp in inside cover from bookstore said $10.80.. That's back when "modern" was 1983..
Dennis Leigh Henry
The machine shop end of my basement shop.. I have a horizontal and vertical bandsaws, arbor press, and a buffer on the other end.. mixed in with the wood working side of my basement. Welding is done in the garage. Sheet metal fab is my next addition.. as well as a shop press that I want to build from scratch.
MetalMangler
Upstate NY
Dan Tootle-
Never having been to Haiti I don't know if my thoughts and pre-conceptions would be valid, however I would ask you to evaluate including blacksmith and basic metal-working in the curriculum. I am envisioning farms across the US in say the 40s. If the farmers in Haiti have something to bang against and a hot fire they can do a lot of rough shaping themselves. Teaching them proper finishing techniques (cutting, filing, etc) they can wind up meeting a lot of their needs without a lathe or milling machine, without a grinder, etc. which might be too much of an investment for a struggling farmer.
Good luck, and let us know how things are progressing!
MM
bczygan
DETROIT! Arsenal of Scrappers
As much as possible, try to create a flow of work through your space.
Materials should come in the door and be immediately stored in racks, shelves and bins, readily available for pulling for jobs. Organization and labeling of cutoffs and good lighting is critical here.
The first thing you will do is to plan the job. This can be in an office area, or at a desk in the middle of the shop. I like working off the granite in a central area. I can take the part drawing and go right to the materials. I like a stool here.
Next is rough cutting the materials. Bandsaws do most of this work, chop saws too. Work should next flow through these machine positions. A roller stand at the horizontal bandsaw for long stock is necessary. Next to the bandsaws should be your disc sander to remove burrs from edges of cut stock and a bench grinder with wire wheels for cleaning up stock. Left over stock is put back on the nearby rack or shelf or bin.
Then you get to your main machining area.
Your major machines are the Bridgeport, Lathe and surface grinder.
I have found that if you set up things properly, you can run 2 or even three machines at the same time. I put the lathe across an aisle from the Bridgeport and surface grinder.
The aisle is wide enough that a short table can hold often used tools. I can set up the lathe to work a part, the Bridgeport to do an operation and go to the grinder to complete some work.
Nearby is shelving with supplies and tools and materials. And a fluids cabinet is also close at hand.
Well placed fans and trash cans serve to keep the shop clean and air moving.
Close to the center of activity should be a bench grinder on a pedestal with green and fine wheels for sharpening tools and bits.
After machining, the part is often welded or finished and sometimes assembled with other parts. These operations are done in separate spaces.
Each major and even minor machine needs certain tools and materials close at hand.
Let's start with the Bridgeport.
To me, the single most important thing is lighting.
After that, a place for what I'm actually working on right at the machine. This includes the part, setup and holding items, measuring equipment, cutters and coolant/fluids.
Usually I will start at the granite with the drawing, grab a caliper and scale and go to the materials rack for the material, the setups shelf for T-nuts and bolts and clamps and dump that on the machine's table. A rack on the machine has most of the regularly used collets. Behind me is a table with often used things, like a drill chuck and commonly used mills and drills. Somewhere nearby is a chest with the full selection of mills. I grab the right one when needed. The same goes for drills.
Another thing I need nearby at the Bridgeport is shields for the hot chips. I also keep the following close at hand. An air hose with an air gun attached, a squeeze bottle of coolant, a cheap paintbrush for chip removal and machine cleaning, a caliper, a couple of mics, scale, super spacer, a few gauge blocks, parallels, tapping equipment, etc.
More machines later...
Bill
bczygan
You can solve some of the problems of having fixed cabinets not being to your liking, by putting them on casters and making them movable.
I keep a bare minimum of tools that are truly within arms reach at a machine. Just the ones needed for the job at hand.
It's OK to use a step or two, on my way from the stock racks and shelves, to gather needed tools and accessories. A step or two away from the major machine area for hold down equipment, measuring equipment, mills and drills etc. is OK.
A table in the center of the work area, so it is right behind me, whichever machine I am at, contains the most often used tools, measurement devices, mills, drills, collets, etc.
Bill
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Bill
Bill....most is spot on and how you described things is about how I laid out our toolroom EXCEPT for the grinders. Grinders can create a vast amount of dust that is very abrasive. You don't want them close to your other precision machinery. I kept our surface grinders up front of the room and away from most machinery. We had two dry grinders and a large wet grinder. Just from grinding one job can create enough dust to start cutting into the ways on a mill or lathe. The dust is not like swarf. We didn't even keep the precision gages near the grinders. And even with using a Torit vacuum on the grinders, the speed of the wheel would still throw stuff past the inlet of the Torit.
Our room wasw relatively small being it was 50' x 100' in size. That seem big when speaking about a garage, but small when you are talking about a room with 5 mills, 3 lathes, three grinders, a couple of large repair tables, Horizontal bandsaw, regular bandsaw, bench equipment like pedestal grinders, carbide grinder, small belt sander and so on, and a large 2 station drill press, plus a large 4x8 surface plate.
We had our benches along the wall on one side, and each toolmaker had 2 benches. I had one bench and a desk. For each toolmaker we each had our own Bridgeport that we ran. The mills were directly across an aisle from our benches. Seeing that mills are used way more than a lathe, our toolboxes were at our bench which put them close to the mills. Across another small aisle from the mills were the lathes. Lathes don't get ran as often as a mill, but normally when you are running a lathe to make parts, you are on it for a while. That's where a rolling toolbox comes in handy. Behind the lathes were all of our cabinets for our gages, perishable tooling, nuts, bolts, screws, and so forth.
Up front, right when you came into our room was our stock racks for our raw materials. Right beside the racks were the horizontal bandsaw, and the vertical bandsaw. This was directly across the room from the surface grinders. This way it kept all of the dust in one area and not gathering on our benches, lathes, and mills.
bczygan
Kevin,
I SO miss working there, but quit because he was not paying me. Still owes me $1,200. That's why I can't wait to get set up here.
You're right about grinding dust. Most of our work was "carpentry".....plus or minus a hammer handle. Still, the surface grinder was set apart a bit, and closer to the stock and bandsaws, than the mills and lathes.
Bill
MetalMangler
Upstate NY
Bill/Kevin/Dan/Everyone -
While I agree that designing a shop to accommodate the workflow is desirable, is it as much an issue in an educational setting? For instance I could see having a large open space so that for instance when you have a project for grinders you can move some grinding stands and grinders into the area so multiple people can work at the same time.
Unfortunately my shop classes were a LONG time ago and I was not looking at them with an eye towards whether workflow was enhanced or not.
MM
bczygan
MM
My posts are in answer to the OP, who is searching for shop layout with an emphasis on having everything right at hand. The smaller the shop, the easier this is to accomplish. In my one car garage/shop, everything is literally 2 or three steps away. I think the OP's idea was to have EVERYTHING needed at any particular machine. I don't think this works quite as well with every collet and every mill and every drill and every possible hand tool and measuring device right at each machine. A step or two away is OK. You gather the tools you need for each setup and take them to the machine. It IS practical and efficient to have a table or tray with your commonly used tools and such, within arms reach of the machine.
My description of a shop layout matched Kevins, because in my minds eye, I was visualizing how I laid out the commercial shop I worked in. In my one car garage, the flow isn't as important. Stock can be stored anywhere in the house or on the property. Usually only one piece will be brought into the garage/shop to be worked on, at a time. And it doesn't matter what the flow is. Every machine is right there. And I'm not going to be doing production, or run automated machines (Except automatic feed on the Bridgeport, so no need to run multiple machines. In fact, space is so much at a premium, that the horizontal bandsaw (On casters), will have to be pulled out for use for long stock. And accessory machines can actually be in other rooms or spaces. Compressor will be for sure. Arbor and H presses will be. Drill presses can be. Welding elsewhere. Plasma cutting elsewhere. Painting elsewhere. In a small house you could use a spare bedroom, shed, the basement or even an unused dining or living room for some functions. These spaces are so close together, that it wouldn't matter.
Lots of ways to skin a cat in a residential setting for a home shop.
Bill
macgyver37
Pittsburg, Kansas
I have my mills all at an angle to the wall, like angle parking cars, that way I can fit them in a little better. I have 2 vert mills and a horizontal and a couple shapers. I have a few tools that stay with each machine that hang on them, the collet rack is bolted to it as well. I have a couple roll around tool boxes that house the rest of the machinist tools. These are usually parked behind me at which ever machine I am running. I also have a mat in front of each machine. This is how I have done it for a long time and it works for me.
The 3 lathes are against the wall with room to hang out the head stock, and I have the extra attachments for them at the end of the machine for now. I plan to make a chuck rack and put a little crane on the headstock end of the 2 big ones to do the lifting of chucks for me.
I still use the roll around box for the lathes and again just put it behind me.
My metrology dept (what little there is) is in my office. I have a 4x8 surface plate in there and the inspection tools are as well.
The fab work is in a different area, I do have a couple bench grinders to sharpen lathe tools etc in the machine shop, but I don't lay on the grinders or plasma in there for sure.
Dennis Leigh Henry
Agree with putting similar machines on the bias. The Modern School Shop Design text above outlines the many benefits of doing it this way as a space saver and a bit of a safety factor too. I.e. think of lathes back to back and what might happen if a chucked piece or oil splash occurs...to the guy or gal in front of you, on a bias this is less of a concern. My high school machine trades shop had 7 13" tool room South Bend Lathes, and 12 10" tool room South Bends in two rows and that worked out pretty well space and safety wise.
