hot rod garage in the works. 38x56
bidouchon
France, Burgundy
hello
as a plumber i have to tell you that your pump may not be mounted in the right position. would be better to have the axle in the horizontal position.
like in this picture
images
would be better for it's life duration
i'm impressed by your work :scared:
E
E.rodz
st.paul MN.
hello
as a plumber i have to tell you that your pump may not be mounted in the right position. would be better to have the axle in the horizontal position. it would be better for it's life duration
Thanks for the interest. I have also heard that the pump mounting is not optimal but it is what it is now not changing anything now until something brakes only time will tell how long that will be?
E
E.rodz
st.paul MN.
kicking it on the chevelle getting the big picture in my head. Ride height,stance, motor location,steering and brakes figured out. Lots of things going on before christmas.made another video the other night still have to do some editing before we can upload it I will post it up when we get the time.don't be afraid to let me know what you think.
E
E.rodz
st.paul MN.
Thought you might want a peek at the state the chevelle in in now. We have been super busy ripping and tearing every thing off the car that we are not going to use and here is whats left.
E
E.rodz
st.paul MN.
Well finally got finished tearing things off the car we are not going to use.lol. pretty much all we are going to reuse is the shell and part of the frame!
LET THE MOCK UP BEGIN!!
as always feel free to share your oppinions!!!!!!
E
E.rodz
st.paul MN.
sorry for the lack of posting . wife has been in and out of the hospital just having a hard time finding enough hrs. in the day to get much done but still chipping away a little at a time. got almost all of the accessory system done and just about ready to get the car frame sent to the sandblaster.
next is the brake brackets
:3gears:
Dillithium
Hi, I hope you don't mind me asking you a question about that engine.
On the first picture you see the intake manifold with 8 inlets on top, correct?
But then on the second picture you see the carb mounted on the front, with the butterfly valve on the front. Isn't that where the connection to the airbox goes? What are those eight inlets for then?
Yeah, I'm i'm a noob. :D
oldsfan442
Fantastic work so far. I love little details like custom home made brackets. Keep up the great work.
Are you going to keep the factory paint or is the whole car getting blasted at some point?
Bryan
E
E.rodz
st.paul MN.
Yeah, I'm i'm a noob. :D[/QUOTE]
is ok to ask questions that how the smarter ones learn! the intake is a factory ls6 intake with pvc glued to it and stacks off a cbr 1000 motorcycle machined to fit the pvc. alot of fab work just for the look of old school FI. the front is a throttle body wich will be covered up. there is 2 different intakes both are plastic. hope this helps.
Bryan
going to get into the body mods soon then sandblasting and paint after that. still a long ways off though.
E
E.rodz
st.paul MN.
been attempting to get some things done on the car it has been a bit slow lately but still chipping away on this thing.
brake brackets almost done and the front drive accessories almost done just a couple of details left on both.
E
E.rodz
st.paul MN.
dug a old electric cabinet out of a dumpster and starting to fab up some brackets for the chevelle.
E
E.rodz
st.paul MN.
ok got a little side tracked on the chevelle and needed to get some shop tool modification done any idea what tool this is going to for for? or what it is?
E
E.rodz
st.paul MN.
That looks stunning!!
Even just the mock-up looks awesome. :thumbup:
If you like it like this just wait till all the ideas come out of my head.:lol_hitti stay tuned on this one there is alot more to come.
Next guess.....For a small set of shears?
nope.it is a nibbler steel fingernail catch pan the nibbler punches 10 gauge steel and it is mounted on my english wheel frame soon to be finished.
IGO2XS
Sarasota, FL
loving all of the brackets you are building. who's control arms are you using on your chevelle project?
E
E.rodz
st.paul MN.
the control arms are from auto city classics in Isanti mn. I belive they are global west copies I normaly like to suport our country but when you are going to cut them up to make the air bag mounts. I do have another set of a restored arms that came off this car sandblasted primed new bushings and painted, also have another set of tubular arms that have smaller tubes than these and rubber bushings that are going on ebay soon so let me know what your looking for and maybe I can help. Ps. I am glad you live that far away because if we were neighbors we would be building cool sh1t all the time!:lol_hitti
E
E.rodz
st.paul MN.
just wanted to share the latest video that we put together. well kind of this is one me and Austin put together while building our killer clock this one is a 2 part so be sure to check out both parts hope you guys like it and please give me your feedback.
video link^^^^^^^^^^^^^^^^^^^^^^
PART TWO vvvvvvvvvvvvvvvvvvvvv
NUTTSGT
Northern Central Ohio
A very good and informative video. Are you thinning the rustoleum with mineral spirits ? That's what I have used but what ratio are you getting away with ?
E
E.rodz
st.paul MN.
tricky question here. sometimes I use acrylic enamel reducer,sometimes mineral spirts sometimes acetone. any of them work it depends how fast you want it to dry and what you have on hand the base coat was done with 4 ounces of hardener per qt. because it was going to be top coated with clear and if you don't use hardener and you top coat the clear it will wrinkle the base coat the airbrush paint is thinned alot about 2 parts reducer to 1 part paint the base is thinned about 20%you can get by with no hardener but you need to let it dry for about a month and your coats of clear over the top must be applied very lightly. hope this helps let me know if you have anymore questions. Thanks for the input.
NUTTSGT
Thank you, I appreciate that. I never thought about using hardener with Rustoleum. :dunno: You're reducing it way more than I thought was possible. I guess it's a trial and error thing, I've never mixed it that thin. I do know, Rustoleum (and that style of paint) requires some thinning to go through a gun made for automotive finishes.
E
E.rodz
st.paul MN.
the massive thinning is just for the airbrush not the big gun for the base. 10 to 20 % is what the base is thinned.
camaro1969
hey bud, its cool what you are doing with your kids, i do the same. you're workmanship on your shop and cars are 2nd to none. anymore progress on the chevelle? looks like you are very talented with the autobody field, is that what you do for a living? keep on keepin on and when i get back to my shop project after the sports season for the kids is done i will post some pics. any project cars you looking for? i live in montana where the cars are still pretty good and have a big network of people and cars available. if you are looking for anything specific post me and i will do some checking. later
E
E.rodz
st.paul MN.
Thanks for taking interest and spending time with your kids! I started another thread build something with your kids please take pictures of projects with your kids and post them up in that thread!
E
E.rodz
st.paul MN.
work has been really slow on the chevelle to many things going on at the same time getting things ready for the air bags mounted! these are part of the new a arms. they are new so why not cut them up!
E
E.rodz
st.paul MN.
you guys want to see our latest video! this is a pretty cool time lapse of the Chevelle tear down. please check it out and let me know what you think!
NEW VIDEO RIGHT HERE PLEASE TAKE THE TIME TO CHECK IT OUT
Nightshift
London, Ontario
Thanks buddy I hope everything has been going well for you! is the snow melting yet? and are you ready to sell me your bandsaw yet?
Ha ha ... I just got home from 2 months in FL ... damn snow is still on the ground here ... about 6". Hopefully it will be gone soon. I'm down to 3 bandsaws but want them all. The DoAll and Rollin are used just about every day when I'm here working in the shop. The Wellsaw horizontal rarely gets used, but it is great to have when you need it. I am watching for a good used DoAll for sale that my buddy wants, but I'll keep you in mind if I happen to notice one in your neck of the woods. Cheers, Bill
