Fasco was a quality brand before they got bought out. You don't add the amperages on both wires. If the load is somewhat balanced, you will have the identical amount running through both feeders. If not consider the higher amperage of the two. What btu ratings are the heaters you're looking at? Your space is insulated about the same as mine. I would pick up a portable unit thats rated at 5000watts and wire up a temporary receptacle for it. The portables are cord and plug. Plug it in and let it run for an hour. See if it makes a difference and if that difference is what you can live with. You could always get a second one or return the first if it's a no go.
I would also consider one of these. The amperage is getting up there, but I think this is a serious possibility. Qmark is a well known commercial brand. The ideal setup would have two stage electric heat. A two stage unit would have two electric heating coils in it. Both come on when it's really cold, but only one when it's maintaining a setpoint. I don't know if that arrangement is made in that small of a unit.
http://www.heateroutlet.com/productcart/pc/viewPrd.asp?idproduct=96
It may say its rated for 850 sq ft, but that's not alot of btus. It requires a 50A breaker but only draws 38A. If you keep the temp around 50 and only raise it up when you're in there, it will probably raise the temp at a decent rate. It also puts the heat out at floor level and we all know heat rises. It would be my first pick if I was going electric. I really think it's the best "bang" for the buck. That's also the lowest price I could find on a counterflow furnace. You also need a 50A, 2 pole breaker, the associated wiring and a 15A mini breaker for your existing panel.
