that would be nice,all 3 seem like useful tools, a decent discussion would be an ideal information source for a guy trying to make his mind up, I'm getting a PP3 and loadpro after christmas (maybe for christmas if santa get my list in time), if this one stays opened ill post my thoughts (that is for the ones who care about a lowly backwoods forklift mechanics opinion)
I hope dan was not run off because I think he could have been very valuable to the forum. Can anyone direct me to an automotive electrical discussion forum?
There's nothing lowly about a forklift mechanic. That's an honorable way to earn a living and I wouldn't pay attention to anybody who thinks otherwise.
You'll enjoy both those tools. Use the Power Probe as a test light and to energize light bulbs, solenoids, cooling fans (do forklifts have those?), etc. Just don't energize something that isn't supposed to be energized. Use the Loadpro to find unwanted high resistance in a circuit. Read Dan's book.
After using your new tools, I for one would like to hear your observations. While you're at it, teach us about forklifts - for example, what kind of engine is underneath the hood (or whatever it's called) of a propane-fueled forklift? Is it fuel injected, with computer control? What kind of faults are most common on forklifts? There's a lot of stuff you know that most other people don't.
I would like Dan Sullivan to keep posting on the forum as well.
It's not a forum, but ScannerDanner's Youtube channel is worth subscribing to. Others have mentioned it, possibly you were one of them. His videos are not about "electrical" in the sense of fixing broken or corroded wires (although he does do that in a few of them), they're automotive diagnostics case studies using a scan tool and a scope. And a test light. With a pointy tip.
Now if we could get Paul Danner to start posting here that would be a real good thing.
I sent Paul Danner an e-mail inviting him to take a look.
Really enjoyed Dans new clip, I hope he sticks around![]()
If Dan is still checking this thread I would like to ask him a few questions about the load pro.
I have a power probe3 and honestly I dont use it for much besides a jumper wire to apply voltage and/or ground, and I would say 80% of those times its to put some customers window up that 'forgot' to tell us their ************* window rolls down but not up. Occasional it gets used to power up a fan motor or solenoid but for the most part that can be taken care of through the scanner.
What are you getting at BC?
Data Transmission network not a safe area to test?
Its OK if you follow the rules, it doesn,t carry a load, so unless you isolate the physical layer from the nodes and power it independently you wouldn,t ever need to use any of those 3 tools anyway. Although you can use a DVOM and Load Pro to carry out some network testing.
That still leaves an awful lot of load carrying wiring to test.
This is the fly-by-wire I know of:
Fly-by-wire (FBW) is a system that replaces the conventional manual flight controls of an aircraft with an electronic interface.
Why do others use it in other contexts?
I mostly use my PP3 for effecting entry into locked cars with the keys inside.
Or I might use it to temporarily run a supply or ground to a fuel pump with a broken/corroded wire to get it back to the workshop.
I think you just learn more quickly using a DVOM, the more you use it the better you get with it, then when you get a tricky job its second nature.
Yeah its everywhere in vehicles at the moment, nothing has a throttle cable anymore, steering and brakes are already up and running in prototypes.
Cars are crammed with networked systems nowadays.
Exactly, it all filters down from aircraft technology.
That's what I'm saying. I was always unsure why he compared the two because they aren't used for the same application. The dvom comes out to diagnose and find problem but when things are being installed its the pp. motor swap on my truck and installing the aftermarket rad fan. Test it works on the bench... Install and make sure it has ground... Make sure it has power then test it in the truck
It's like needle nose vs lineman pliers. Similar but different
You understand the limitations of the PP3, not everyone does.
bingo. I don't think he was out of line showing what the tools limitations are in a diagnostic situation. Quite a few members here talking about the PP like its a do all. All I've ever seen it good for is acting as a quick jumper.
Yes, I think that's the best one-sentence piece of advice in all this discussion.
You can do anything a PP3 does with a DVOM including powering up components and you get to see the amp draw as a bonus![]()
I have a couple of questions about the PP3. I don't own one, but was thinking about purchasing one.
What sorts of things does it power (I know fans and lights, but what else)?
What should you not try to supply power to with it?
Also it supplies power/ground. Does it do both at the same time? If so how?
Don't mean to go off topic, just curious.
