Looking for a good awl
AZ_Catskinner
Morenci, AZ
The best one I have is a worn out phillips screwdriver that I ground to a point and hardened.
I like the old wooden handled Stanleys for premade awls.
Mastermind
Ypsilanti, MI
+1 on the junk phillips grind and harden.
also have a snappy thats kinda thin, havevhad the stubby handle snappy that was beefier, had a wilde that i loved, it disapeared. harry epstiens carries wilde i've seen, and i've heard great things about them here.
onewaydave
Down the road from Dorothy and Toto
What kind of awl?
A handy scratch-general-marking-use awl. Any high carbon steel, grind, file and hone to shape. Make a handle out of a nice piece of hardwood using a lathe, drill press or hand drill. Drill a hole in the finely shaped handle and epoxy it in. Much nicer than plastic even if the plastic says Snap On.
A leather sewing awl. Made the same, but the cross section is diamond shaped and is sharp on the 4 corners. Sized to the size of thread which is sized the size of the leather.
A wood marking awl. Don't go round but use a marking knife instead. Crisp sharp lines. Made the same way.
A glass cutting awl. Get a cheap carbide marker off ebay. Good for the machinist also. Well for one that doesn't still use Chemdye to layout anymore. Can be mounted in a similar handle.
Dave, on a "make one kick" tonight.
MP&C
Leonardtown, MD
Scratch awl? Best I've gotten are old ice picks that came from auctions..
Never sharpen on a grinder, use a fine file. They last much longer that way. ;)
Holt
Bellevue, Nebraska
I have a old Klein that wont quit. Ive beat the hell out of it. Handle is in good shape. Note I said old Klein. New ones are most likely junk.
Steve_P
Of what I can identify, I have a couple by Wera and also a General branded one from Epstein.
