brihvac
When I installed my lift I screwed up and should have drilled my holes deeper. I did not realize the bolts would pull up so far when they tightened. After I had my truck on it, I noticed the post were loose. I tightened them again but Im sure they will loosen more and to be honest with you, I dont feel safe under it. The directions that came with the lift are horrible. After searching the net, I found that most manufactors suggest you drill all the way through the foundation. Reason being if you ever need to move the lift,etc, you can just pound it clear through. The existing anchors are 5 1/2" wedge. I want to get them out and drill deeper then use 7" anchors. I was thinking of taking the nut off, then using a piece of pipe, make a spacer and screw the nut back on and tighten the hell out of it. Hopefully it will keep pulling up out of the concrete. If I had to guess I would say there is only about 3" or so in the concrete. In a way Im glad they are pulled up as far as they are because maybe they will be easier to get out.
Any other ideas?
Also I was going to take advantage of the Zoro tool sale and buy anchors.
Here are the 2 different ones I was looking at.
http://www.zorotools.com/g/Carbon Steel Wedge Anchors/00096058/
http://www.zorotools.com/g/Wedge Anchors Zinc Plated Steel/00113932/
Both are 3/4 dia. and 7" long. However one is zinc plated and the other is not. Does it make a differance? The price is double for the zinc plated. Greg Smith Equipment sells the 7" anchors for $7.00 each. They are local so there would be no shipping. However I would save money ordering them from Zoro.
Any advice is greatly appreciated.
Any other ideas?
