The VISES of Garage Journal
Adam McLaughlin
Santa Rosa, CA
Refinished an old Rock Island that I bought in a vise batch a couple of years ago
Sand blasted it, primed it, painted the body gloss black with some white enamel on the letters. Cleared the whole thing and added some 5/8" hose washers on the handle.
Added a BUNCH of anti-sieze to the threaded rod inside for super slick movement.
And yes... it gets used for transmission work. Holding pump bodies for PR valve spring changes, holding shafts for bearings, even 4L65 forward drum shafts for the clutch and steel loading steps.
Here are some snapshots
Adam
andywander
Nice vise!
Does anyone know why so many vises have the "overhang" in the casting of the dynamic jaw, that covers the top of the screw? I see it on this Rock Island vise, the 4" Fred C. Moran Double Swivel a few posts back, and also on my Trojan a page or 2 back.
LostHSV
Alabama
This is a 1912 Athol Vise-No 681 I picked up from CL recently. I'm pleased with how it turned out.
Mohawk Dave
SoCal
Nice vise!
Good question. From what I deduced, it does nothing structural, so it must be simply to protect and guard debris from falling into the mechanics of the screw. Anyone else?
RivennHewn
PNW
Added bearing surface for the dynamic jaw when extended.
Helps keep the jaw from dropping and binding.
Mohawk Dave
SoCal
I believe you are talking about the support on the bottom. The Q was for the little overhang on top of the handle on the dynamic jaw...unless I'm confused and now confusing you guys too...:headscrat If so, sorry...
RivennHewn
PNW
My bad. I scan more than I actually read sometimes.
Mohawk Dave
SoCal
My Fred C Moran 4" Double Swivel. Here's the link to the restoration. http://www.garagejournal.com/forum/showthread.php?p=2798178#post2798178
As of now...still need the adjustable handles...
<a href="http://imgur.com/FpyTi"><img src="http://i.imgur.com/FpyTi.jpg" title="Hosted by imgur.com" alt="" /></a>
Hey Outlaw, autopts, and all others,
I read through GJ on clear coating a rattle can vise, like mine above, but did not get a thorough pros/cons list on it. I have not clear coated this one, in thinking that touch up would be easier without it. Can you guys school me?
Thanks!:beer:
bmwpower
I personally like the non-gloss/clear look. Looks more original to me...
C.BRAXMAIER
Christ! Are big vises falling from the sky around you Chris? ........Guys, that's a C3 with the older 600 style jaws on it. Wilton does not make that jaw design anymore and its too bad. That's was a hell of a setup.. The Dynamic jaw is so heavy with the pipe jaw in, it can't support its own weight even when the base is properly positioned. It tilts forward. Also, that close up of the channel bar? That's a steel bar that actually pressed into the Dynamic jaw. If Chris takes that collar off, he will see the top of the dowel which sets and keeps that bar in place. That's a great find!!
here is the front.
Catalyze
New Mexico
Adam - those Rock Island vises are just classic looking.....I like my old one too
Lost - very nice Athol restore! That company had some of the best machining on their vises including knurling on the swivel base locks
Mohawk - I don't use clear...it's just one more layer to chip and then you can't just rattle can touch up in one step
Craig
SteveL
St. Louis, MO
Anyone know what color an old Reed no. 404 was when new? I have one that it likely way older than I am that was painted a dark gold color sometime in its life and I would like to restore it one of these days.
I've restored a couple of wood bench vises but just used dark grey hammered paint and although they look good I'm sure they are nowhere close to original.
autopts
here is the front.
Thanks Chris. I call it a dowel but its whatever holds that steel slide bar into the Dynamic is at 1 o'clock. Earlier C 3's were one piece.
I got a deal on this 600S. It had been dropped. I had 2 guys help me put it on a press table and It straightened out under about 400 lbs
Lump
Jamestown, Ohio
Wow, Autopts. That's impressive! Did you have to heat it to keep it from cracking under all that pressure? Amazing that you could straighten it out. By the way, is this photo a "before-the-400-LB-press," or an "after-straightening" shot?
Most Likely semi gloss black.
autopts
Nope, I didn't even think about heat. It was straight aftewards Actually if I can remember, in the auction photo it was straight and on the floor. When I got there it was up on a steel bench like that. I got it for $80. The real prize was a gamble I took on a Keithley meter for $25 which netted me $1400. I had no clue what it was. I was on a roll that day. Maybe 3-4 years ago. I sold that 600 a few months after I bought it.
wxm
Guys, some of you may not know how mammoth of this C 3. The swivel base assy. is the same one they put on their monster 800S. Almost 12" across.
That's a good one autopts. Personally I always prefer Parker over Wilton because those mounting holes/screws in front of the jaws for Wiltons. This is the first one I have seen that doesn't have those annoying holes.
autopts
I love Parker vises and don't read me wrong, but I do believe their jaw design is worse then any USA made vise with screws facing front. Replacement Parker jaws are not to be found and making a new set is very labor intensive. That's just my take on it. It amazes me Parker, at sometime didn't improve that jaw design after all those years to a conventional step that the jaw would sit on. If that was a Patented design by Parker, I doubt if any USA vise MFG's thru those decades would have used it. They are distinguishing but never the less a horse **** design. Most old Parkers jaws out there are worn smooth now with most owners scratching their head as to where to find a new, steel, heat treated, serrated replacements for their Parkers that probably have another decade or two left them.
I think if you commit to replacing your Parker jaws with KMSscott (GJ Member) and enough of you do, word has it he may start to make them later this year. Remember, Its a one time investment, buy 2 sets and break down labor costs.
jzt
Dallas, Tx
Columbian 506M2.
The vise was free, sat outside for 10 years. Threw it in vinegar for a week and then painted it.
wxm
Not sure I'd agree with your view about the Parker's jaws. Those one piece wrap around from the top design allows much bigger contact area than the bottom support design used on Wilton. I believe most of the smooth jaws on Parkers were not from wear, they were made this way on purpose so that the jaws would mar the work piece. Anyway, I do agree that the jaws on Parker are a lot more expensive to manufacture, alone with difficulty to replace which, in my opinion are the reasons they are no longer seen on the modern vises...
Catalyze
New Mexico
I was drinking heavily the other night and channeled Mr. Parker himself. He told me that the design started out to provide a replaceable wear surface where most of the damage to a vise happens: on the jaw tops. He told me further that it also allowed them to advertise this design as being "improved" over other brands. In the old days when vise makers were plentiful, you needed something to distinguish your brand over others. Finally, just as I was opening up the can of Sterno to have a last cocktail, he whispered to me that every Parker made would have to get new jaws from his factory....guaranteed income due to a totally unique design. Once I drank the Sterno, I lost him and started arguing with Elvis again about banana sandwiches.
Craig
autopts
Craig
Isn't it amazing what a remote New Mexico climate can do to someone's thought process? Roasted and Toasted!!!
Lump
Jamestown, Ohio
I've FINALLY decided which bench vises to keep and mount for my own use (been using c-clamps for too long, unwilling to make holes in my bench till I made up my mind. LOL.)
Anyway, I have now put 12 bench vises in the GJ classsifieds, if any of you are interested in checking them out.
I have not yet decided whether I will keep that antique twin-screw chain-drive vise, the giant Ridgid vise, or my rotating-slide Chas Parker vise. I will keep you posted on my decisions about them. (They are all featured in old posts in this thread.)
Right now I'm headed to my hunting cabin in southern Ohio for muzzle loader hunting today (Sat) and tomorrow. Wish me luck!
bigcaddy
Orange County/ San Fernando Valley
Here is my completed Wilton 1645 that i picked up last weekend. It came out pretty nice considering how it looked when i bought it.
I've cleaned up quite a few of these and this one has some different features when compared to other medium duty Wilton vises.
it has dual lock downs on the base, which is a 4 hole mount instead of 3. Its also a much beefier casting then the typical light duty vises.
The front operating nut is held in place by a horseshoe shaped retaining ring in front of the jaw instead of an e-clip behind the jaw. Its similar to the heavy duty bullet style vises but has the bones of a light duty mechanics vise.
BJ42LX
WNY
I picked up this Wilton 1755 at auction today. Check out the jaws - :shocking:. It's either a project or a parts vise. Either way for $9.81 it's a deal.
autopts
Dawg!, Your getting vise restoration down to a science! Another beauty. Your vise collection is growing and from what I've seen, its very diversified and mostly all in very good condition. You are getting to be "Mr Big" on these vise threads no doubt.
RivennHewn
PNW
American Scale No. 212A.
4.5 " jaws.
In the process of gett'n her clean and naked.
Wilton / Snap on 1750
No manufacturer's name, but had sticker residue on the sides.
I'm assuming it's a later model (AKA offshore)
Missing one of the pipe jaws, and all four insert screws are broken off. (previous post)
jagleaso
My latest resto:
Desmond Simplex 350, small and handy. Going to mount this to butcherblock top on HF 44box when I get around to it.
