Convert 240 to 120 ?
Hi all. I live next to a river in central MN and use a sprinkler pump for my irrigation system, sucking water from the river. It uses a 220v circuit with the plug pictured below:
I have made an ice rink on the river which is a lot of fun. However, when it gets dark, the fun is over. And as many of you know, it's dark pretty early. Sooo, to extend the use time, I'd like to run a couple 500 watt halogens. I'd love to be able to use that power source as its so close, but not sure if its possible.
Keep in mind I want to use my sprinkler pump starting in the spring. Can I use some kind of step down voltage converter.
Is it possible? (And hopefully without digging into the electrical box)
