MP&C
Leonardtown, MD
Re: what did you do in your garage today?
Shaved the bottom seam on a 55 fender
Thread:
http://www.garagejournal.com/forum/showthread.php?t=182565
ruby76
Fairview Hts, Illinois - outside Saint Louis Misso
"yesterday" - replaced the timing belt and water pump on a 3.5L 2006 Chrysler Pacifica. I think it took me longer to reposition/install the power steering pump (needed removed to get to the timing belt cover bolts) than it did to do the whole project. Today - started to put some of my tools/mess away -but that got sidetracked by unseasonably warm weather and watching the kids play outside till it dropped 30 degrees this afternoon.
RS69
Galena, OH
I did an oil change on the duramax. We had great weather today in central Ohio, over 60 degrees today.
BJ42LX
WNY
Assembled my welder extension cord.
KB1LTG
Here are my pseudo-butcher block bench tops I made out of some cheap DF 2x4"s and a little scrap purple heart I had laying around :)
You can see mostly how I did it here, along with a cheap DF 2x6 laminated leg build...
http://lumberjocks.com/projects/22183
ENjoy
Jerry
Outlander
Quebec, Canada
Drove around looking for CV boot clamp and tool for my Outlander (broke one last week). Of course here in the country the auto parts stores close at noon and I was to lazy to get going this morning. Burned a lot more gas than the products were worth!
mothgrey
Fixed one of my ATV's today and almost done putting her back together. Replaced the choke cable on the other.
GTA Matt
Zebulon, NC
Took advantage of the warm weather. Changed spark plugs and power steering pump inlet o-ring in my buddies MDX. Then pulled the rear out of my car. Trying to decide whether to clear coat it or paint it. Stuck it in bare just to make it a roller a few months ago. Rubbed it down with steel wool but still can't decide so I moved to the carb on the 4 wheeler. Floats stuck a few weeks ago, and the gasket between the carb and head was cracked so I pulled it apart for a rebuild. Fair amount of **** and corrosion inside of it. Stuck it back on and called it a day.
zjrog
Tooele, Ut
Cleaned the fuel lines and fuel bowl on my snowthrower. The 2 stroke oil had become nearly like wax. Thrower runs fine again.
socapots
Canada
Couldn't get to the shop today.
But a few days ago i got a rotisserie for the project car.
now if i can only find time to work on it. lol.
Hotrod barn
South east Ohio
I hung a couple pcs. Of OSB,chalked the rest of the seams and painted...I have paint in my garage whooo made progress the last two days since it was 60.needed some warm weather pulled the Torino out for a ride.almost forgot I put rear brakes on the Lexus and shot the bull with one of my buddies.dam I am wore out.
hchinaski
Los Angeles, CA
Built new enclosures for a pair of early 60s dual-concentric ElectroVoice speakers I found in the alley behind an In-N-Out burger and installed them in the rafters of my garage, wired up to a little 4w tube amp I built.
Finally - tunes in the garage!
Always_Thinkin
Illinois
Worked on building my homemade workbench vice. Getting there.
info2x
Berkley, MI
Reinstalled my garage door opener after replacing the gearbox and tube support. I also beefed up the mount so it wouldn't tweak itself to death everytime it turned on. So much quieter and smoother now.
JimVonBaden
Northern Virginia
Looks cool as is, but I bet it would look even better painted.
Jim :cool:
CC1221
ran about 150' of 3/4" conduit - all exposed romex must go!!
SteveL
St. Louis, MO
Replaced the idler pulley and belt tensioner in my wife's '02 BMW 330Ci. Special tools and a trip to the parts store for T50 torx bit.......newer cars are a pain in the ****!
Thank God for U-tube. This would have taken a lot longer than it did.
maybe smith
Volunteer State
I stripped out and rewired my Blackhawke bench drill press and purchased materials to move my air compressor. (wire and outlet)
stitan06
took out cheap metal shelves and built a workbench starting to organize the garage
In My Garage
ON
Drained / flushed my power steering fluid and crossed another one off the to-do list. This was so easy with the new lift.
b7labelle
Took apart a mixer I picked up for 20 bucks this morning on CL.
It's a Kitchen Aid UltraPower Mixer. Works perfectly. The owners were getting rid of it because oil residue was weeping out of it and they didnt want to deal with fixing it...........ok.............
Anyways got it home and within 10 minutes had it apart in the garage. Didnt take any "before" pictures..
Grease residue was weeping from this interface. I took it apart tp figure out what was wrong and didnt take pictures of it all together. Here's where it was leaking:
EWWW!!!! Grease has deteroriated. Ordered a new gasket and some food grade grease for less than 20 bucks. Will clean up and resell for a little bit of profit :pimpflash
NewShockerGuy
Northern Virginia / DC
Butcher block top on workbench/base cabinet DONE, shelves installed in cabinets and car stuff and bike /goodies inside.
Air hose reel mounted.. DONE... Love getting stuff done, this weekend proved to be great...lol
More to come!
-Nigel
Hawk Thor
Iceland
Tore an old Miller spotwelder apart to clean it and figure out why it was shorting out. Reassembled and spot-welded some scraps till I was satisfied it was working properly.
In My Garage
ON
Took apart a mixer I picked up for 20 bucks this morning on CL. It's a Kitchen Aid UltraPower Mixer.
Thats an oldie and I know people that have them, not quite so old, but they're still ticking. Made in the day when stuff built here was well made. Mine is maybe 15 years old.
Works perfectly. The owners were getting rid of it because oil residue was weeping out of it and they didn't want to deal with fixing it.
How typical in our throw-away society. Their loss; your gain.
BTW, if the gears are plastic/nylon, you might want to use a food grade grease compatible with that material. I'm not up on that, but maybe some type of silicone grease.
malibutwins
Upstate NY
I installed a 46re transmission in a friends truck I rebuilt. Yup it doesn't shift right ugh!!!
dirtmister16
wisconsin
sorted a few coffee cans of nuts and bolts today. made some labels and labeled the bolt bins.
i really wish i had more room to organize things differntly as i have alot of misc. hardware from small engines that are specific to those items alone.
we will see what else i can do yet.
