Felo Screwdrivers
Monte
Germany
lok, do you have stored every single post from the "Tools from ...." thread in your brain ?? :D ;)
Blöckw@rt
Germany
I find the e-smart very convenient to have a small box with many different "screwdrivers" available. The workmanship and quality is very good, typical Felo.
Outline
's-Hertogenbosch, The Netherlands
I don't know if anybody has posted this test here already: http://www.selbst.de/sites/default/files/test-schraubendreher.pdf
And if anyone can help me with a good EU (German?) Felo dealer who doesn't want full list price plus a little bit extra?...
(Long story short: Local dealer is trying to pull that because of 'special order'. Doesn't know I contacted Dutch distributor who says 'special order' is ****. Distributor however did not supply adress for other dealer...)
geo9
Greece
I have found good prices for the most common Felo screwdriver sets in Amazon.co.uk and Amazon.de (the latter has more choices), if you haven't checked yet
Edit to add: Thank you also for the screwdrivers' test!
Monte
Germany
http://www.thefelotoolshop.co.uk/
Tooling Around
Anyone tried the Felo Bit-Boy screwdriver? I've read that the cap can come loose while in use.
dutchgray
Dorset. England.
Bit boy turned up today, will try it out tomorrow, I would say get one though, the only weakness with the cap I can see is that the locking tabs could get broken if it was dropped while open, its actually very tight to lock and unlock, so should take a while to wear loose. Bit holder magnet is very strong, bit holder locks into the handle well, handle is quite large, the bits are retained in the internal holder by magnet as well which is nice.
Brungilda
Hey, Guys!)
My name is Nora, I'm a girl from Moscow. I am a member of the construction and tool forum and we also love Felo tools.)
Some time ago, I did a little research by cutting up Dexter Pro PH 1 (the similar Felo Ergonic screwdriver from Leroy Merlin - Europe) to see what's inside (gel etc.). Have any of you done any of these experiments with Felo Ergonic?
Thanks for reply!)
Kasal
Galicia, España
I thought you might find them useful:
Felo 61391, lot 17 screwdrivers with support.
