I started a thread a while back on using 2ga aluminum wire for this circuit. I ended up buying a spool of 1/0 copper wire. While in the shop today I had a few questions.
1. If I understand this correctly I can add a 100 amp breaker to the current panel and tap off of that. I want to start/run a 30hp three phase motor for a phase converter(FLA is 71.6 amps on 230v).
2. Can I run off the panel into a 100 amp disconnect (fused)? instead of a main lug or panel? I don't need extra circuits just the 100 amp one.
3. From the converter I would like to feed it into a three phase panel I already have.
