Siding help
jkruttlin
NE MI
I recently finished my garage project. I had a contractor rough-in and frame it and I would do the siding. I did have the contractor start the siding and put down the starter strips. After I rounded the last corner I noticed the treated plate was very visible in the front and not in the back. Everything else is square. How big of a deal is this?
danski0224
Near Naperville, IL
Slab may not be level, but the starter strip probably is.
If it isn't out much, you can move the starter down and cheat the siding a little as you go up.
J
jkruttlin
NE MI
Updated picture
The corner was put on by the contractor.
jp small engine
If your build was the same height as the corner is tall he moved it up so that it would be less noticable than a gap at top. It is common unless you want a seam in corner
