pitterpat
Ok, finally got time today to get most of the new breaker box/sub panel installed. What do you think? From this thread http://www.garagejournal.com/forum/showthread.php?t=179803 , I had a "real" small MLO as a sub panel. Now I have the new breaker box and was wondering what you thought of my wiring? Yes, it is not finished and the wires are connected to most of the breakers; some are too long but that will be tightened up after I get your opinions. Tomorrow I will shorten the wires that need to be shortened and make all of those square tight bends. Also the insulation for the 50 amp breaker will be stripped off like it should be.
Here's what is on the breakers:
1 / 3 - 100 Amp DP Main Breaker 2 - 20 amp breaker for outlets
5 / 7 - 20 amp dp breaker 4 - 20 amp breaker for 4 gang light switch
6 - 50 amp breaker for spot welder
8 -20 amp dp breaker for outlets
Like I said, it is not done yet, will make everything cleaner tomorrow. Let me know what you think.
