taking apart a S-O ratcheting screwdriver
plinker
Northern Wi
Here is how to take apart a Snap-on ratcheting screwdriver for cleaning, greasing or converting to interchangeable blades/shanks.
Edit to add (4/23/18); The following applies to all ratcheting screwdrivers, 1/4 spinner handles and T handles branded for Snap-on, Williams, New Holland, Brownells (blue T-handle).
The mini ratcheting screwdrivers cant be disassembled that I know of.
You will need these type of pliers, mini needle nose.
Here is the notch for the retaining spring.
Step 1: Put screwdriver in locked position, mark/make note of retaining spring notch location. This will help in lining up when putting back together.
Step 2: Take fine needle nose pliers and squeeze retainer spring nubs together and lift cap up. The reverse cap shouldnt be on too tight to where you need to pry it off.
Here is the cap removed with a shank in place
This is what you'll have with the fixed shank removed.
Step 3: Make sure you dont lose any internals. There is a plunger that likes to move or stay in the cap. pic has the soft grip and hard handle shown.
asfar as I can tell there is no differnce in the internals.
Step 4: If rebuilding, replace parts and skip to step5 If removing shank to allow multiple shanks/blades remove "spring ring retainer" from shank.(looks like a lock washer)
*Notice the soft grip handle has a rubber washer/bushing that fits in the reverse cap. This helps hold the interchangeable shank/blades in the handle. I need to find a source for these. It will work without it, but would hold the shank/blade better with it.
Step 5: Reinstalling the reverse cap; find out where the notch for the retaining spring tabs go if you didnt mark the location. Place retaining ring on handle partof screwdriver squeeze the tabs together and place cap on screwdriver. Remove pliers and make sure cap is fully seated. *** similar to taking apart an S-K round head ratchet.
*This step is fairly difficult, it helps to have a third hand and/or a vise. It may take a few trys to get it right. I have taken all of mine apart several times and I still have some trouble once in a while.
Notes.....
Taking out the pawl & gear for cleaning/greasing isnt difficult. Basically all parts just drop back in place. One thing that grease will do is quiet down the clicking noise. It does not take much.
The soft grip handle has a smaller notch for the retaining spring, therefore you may need smaller tip pliers.
The part #'s for the black end cap is: SSDMR4A200R 3.20$
The part # for the black reverse cap is: SSDMR4A6J 5.15$
The lime & black screwdriver I picked up off of ebay reasonable, it was missing the end cap and the reverse cap was shrunk from heat I think.
Anyway I replaced them and it looks kinda cool.
Handle size differnces
My ratcheting screwdriver collection.
I think this should cover everything, unless I missed somthing....
Sorry about the pic's they were really good but somehow got to look cartoonish for some reason?
eschoendorff
Dude, you rock. Thanks for posting that up... I always kinda wondered what it would look like if I pulled my S/O ratcheting screwdriver apart.
billymade
New Mexico
Thanks for the strip down, rebuild and screwdriver autopsy! The idea of replacing with different colors adds a whole new dimension of color possibilities! Did you get black replacement parts because they were the only color available (on old style handle) or because you wanted the black color?
P
plinker
Northern Wi
Does the replacement end cap come with the beveled washer/gasket?
No, this would probably come only with the kit for the soft grip version.
I intend to look into finding a suitable replacment.
For the reverse cap, red is still available #SSDMR4ARAC6J (I ordered one before I found the # for the black one) It took quite a bit of digging to find the black end cap part number(found # on ebay). Most other colors are not available.
It's a PITA to look through S-O's parts catalog find the item and its not available even though they still list these parts. They really need to update.
TheToolMan
N.J.
WOW i really love this site i am going to do this tommorow to all ,y screw drivers and convert them to interchangeable, I have gasket material that i think i can make this seal i will lat you know how i make out, THANK YOU
P
plinker
Northern Wi
do not find a notch for snap ring on my Gearwrench ratcheting screwdriver
That's because all the screwdrivers in this thread are Snap On. GearWrench autopsy is next month
My Snap-on mini ratcheting screwdriver dosent have a notch for the retaning ring, So I guess it aint rebuildable :headscrat:
wilbilt
NorCal
Just to clarify, I am talking about the rear end cap that encloses the bit storage. It looks like there is a gasket there in the pic.
eschoendorff
I'd have to go out and look at mine, but for some reason I thought it just had an O ring back there...
P
plinker
Northern Wi
The end cap dosent have a gasket, I think theres an O-ring but I dont rember.
I have a 75th anv. version that has a gasket, but my '99 packers version and my Moms '97 pink handle version both have O-rings. ('99 & '97 is when they were bought new)
wilbilt
NorCal
The pink one I bought for my wife used to have a pink tapered washer or gasket between the cap and the handle. My son used it one day and the gasket disappeared (along with all of the bits).
It looks strange without the gasket, as the cap doesn't fit against the handle like it should. I did put an o-ring there to help keep the cap from coming loose, but it leaves a gap.
In the picture plinker posted showing all of the screwdrivers, it looks like the upper right black-handled driver may be missing the gasket, but the other black one and the green one appear to have them in place.
bchee
Texas
YES, EXCELLENT INFORMATION AND PICTS. Too bad I don't have a snap on. I'm going to take a closer look at my gearwrench to see how it comes apart. I also have a gearless stubby that I'm curious about now (made by amco).
Toolhorder
Montana
Okay so I'm curious because I see the long shank ratcheting screwdrivers going for a small fortune on feebay. If you make the hard handle version accept different shanks does SO sell the long shank as a parts replacement?
P
plinker
Northern Wi
As far as I know the long shank is not made anymore( I might be wrong). It probably would not work as it has no detent ball, so it would not stay in the screwdriver handle under it's own power.
The ones available with the detent ball are 3",6" and 9" long.
A neat trick I found is to take a 1/4 drive extension and use it "backwards" to add legnth to the shank you are using. (the square drive end holds a SD shank)
Gearwrench also makes a coupler to add the 1/4 drive shank to a regular shank, I dont remember the part # off hand though.
Toolhorder
Montana
COuld you post a picture of this extension trick? I have a couple hard handled and one soft grip ratcheting screwdriver. I'd like to have the length for certain applications (like taking side marker lens off on 94-97 Accords) which have #2 phillips screws recessed further than a normal shank can reach.
MattT
How much are they fetching? I have a barely used one I have no emotional attachment to.
Regards S-O switching from the gasket to that ******** o ring on the end cap what the **** were they thinking:headscrat It ain't an improvement.
P
plinker
Northern Wi
I have a camera, but takes me too long to upload pics(dial-up).
But more or less take the end of the extension that the socket goes on and stick it in the screwdriver, then take the ratchet end of the extension and put the shank in it.
neblinc
Lincoln, NE
I have an orange handle one and the reverser cap broke, can you still get that part in orange?
Took mine apart to clean and lube, must have lots of patience to tackle this :willy_nil
Randy
P
plinker
Northern Wi
I dont know, I do not have the part # for orange, but I do for black.
SSDMR4A6TT BLACK PP REVERSE CAP 3.75
SSDMR4A200R BLACK END CAP 3.30
neblinc
Lincoln, NE
Chadster, I almost placed the order but it says endcap, I need the piece that you reverse the ratchet with, not the bit storage cap.
Randy
chadster1
Terrell, Texas
Randy
I dont think that part is available. The entire ratcheting screwdriver is a warranty item and the SSDMR4BO is still available. You should just get the entire screwdriver replaced.
dlfiene
How much did the 24" ratchet screwdrivers cost new off the truck when they made them?
Teikas Dad
Connecticut
Outstanding thread! I have a hard red handle S-O ratcheting screwdriver that my father gave me 25 or maybe 30 years ago....I think it was when they first came out. My father was a diesel mechanic for over 35 years and wouldn't have a wrench, socket, ratchet or any other tool in his work toolbox unless it said Snap-On on it. He died 12 years ago so the screwdriver (and all the other S-O tools that he had which went to my brother who is also a diesel mechanic) outlasted him.
It broke on my about six months ago, would only work in one direction. I bought a Kobalt ratcheting screwdriver as a replacement for around the house, but couldn't bring myself to throw away the S-O, emotional attachment. I was thinking about buying a new one until I saw the price.
Anyway, this thread has put new life into the screwdriver. I went on to S-O's website, found the repair kit and ordered it the other day. Came in today and it took me all of 5 minutes to disassemble, replace all the parts and reassemble - for $10. Works just like it was brand new!
Thank you for posting this!!!
jerryW
Phx AZ
I just received my orange handle toady from e---. SSDMR4A, and it does have a gasket at the cap.
Had to look up this post to see how to clean and lube it. Took me only about 3 minutes. I guess I got lucky. I can see what you mean about the retainer ring being a little hard to get it in.
Working nice and smooth now!
thanks for the tutorial!
jerry
greenreese
I think it's kind of funny that there is a tutorial on how to rebuild a screwdriver on a website for mechanics. I mean, I love tutorials and pictures and step by step an all, but, ya know, it's a screwdriver....
jride200
Any updates, on the rubber washer/bushing in the reverse cap? Has anyone found a source? Or, as an alternative, could I simply purchase a reversing cap for the soft grip screwdriver? I'd like to begin purchasing some of the ratcheting hard handled collection (really don't like soft handled stuff), but I'd like to be able to change out the shanks. Thanks.
ricleh
Sacramento, CA
I took the rubber washer out of one of my soft handled screwdrivers and measured the thickness at about 1/16". The outer circumference is about 5/8" and the inside circumference is about 5/16". I ordered a square piece of rubber from McMaster-Carr that is 1/16" thick. I used a 5/8" gasket punch to create the washer. I then used a 5/16" gasket punch to punch out the center portion of the washer. I was intending to transform my 5 hard T-handles to removable shanks like the soft handled ratcheting screwdrivers. The problem is that the shanks in the hard T-handles do not have a retainer ball in the end of the shaft so they fall out of the handle. The shafts for the soft handled screwdrivers with the retainer ball work just fine. I didn't want to throw out the original shafts so I tried making the center hole of the washers 1/4" instead of 5/16". It worked just the way I hoped it would. The smaller hole of the new rubber washer grabs the original shaft and holds it firmly so it doesn't fall out of the handle. I have converted all 5 of my hard T-handle ratcheting screwdrivers to removable shanks.
