Impact driver bits...where to buy?
Daddy454
Spring Creek,NV
Just like the title says,I broke my Phillips head bit for my impact driver a while ago,and can't find one locally for some reason.Whet do you guys find replacement bits for yours?Checked HD,Ace, even local Fastenal dealer.Nobody can point me in the right direction.Hate to have to order 1 bit online.
shoturtle
Frankfurt AM
given the wera impaktor and the shockwave. Which I have own both. The Wera is the more durable impact bit. The shockwaves are good, and easier to pickup at any H-D. And compare price, the shockwaves are cheaper as well.
shoturtle
Frankfurt AM
They are, I wore out 2 shockwave for every 1 impaktor I wore out. But all impact bits fail sooner or later. And the impaktor were always later.
D
Daddy454
Spring Creek,NV
Dan,Lotso,and Shoturtle-see I asked at our local HD,and they said they didn't carry any impact driver bits.I even looked around and I couldn't find any.I'd assume they would be in the same area with all the other hand tools,no?Maybe I gotta go look again.
demographic
The Duchy of Grand Fenwick, otherwise known as Gre
Milwaukee Shock Wave bits from HD.
Dan
These ones?
They are honestly the worse driver bits I've ever had the misfortune to purchase.
Seriously they were total junk and I'll never buy another.
mobiledynamics
Gotham City
Lemme ask.....are you really seeing that much of a difference..
I've yet to buy a impact bit.
I have TONS of Apex bits. I mainly frame with Torx or Square (depends on which screw bucket I happen to use). I've yet to have one wear *more than normal* on the same bits I've used on regular drills framing..
shoturtle
Frankfurt AM
simple answer, Yes they make a huge difference when you are building with hardwood. We built a deck with the wera impaktor and they were so much better then the non impact.
03protege
Louisiana
Are you referring to an electric impact driver or are you talking about the hand held whack it with a hammer impact driver?
I use the long shockwave bits and am satisfied, I generally will lose the bit before it wears out.
My hand held impact is part of a matco kit, and I haven't had to replace bits yet.
shoturtle
Frankfurt AM
electric, I have use the wiha, wera and shockwave on a bosch 18v impactor. The hand held I used had 1/4" as well.
D
Daddy454
Spring Creek,NV
Hand held whack it with a hammer.Are the ones above for this style?
mobiledynamics
Gotham City
Heh. Maybe when I eventually run out of my stash of bits...
I've got way too much in the T10-T20, #1 and #2 Square, and the list goes on....
shoturtle
Frankfurt AM
is the bit adapter 1/4" ? The ones I have uses had 1/4 adapters. If your is 1/4 hex. They the milwaukee shockwaves will work.
D
Daddy454
Spring Creek,NV
jhelrey
MN
I personally like the 5 or 6 inch Milwaukee ones myself... I use mine daily and rarely do they break. I've even had the ladies at work use it and I can hear it grinding away.
rmsg0040
Toronto
I myself ordered the vim ones from tooltopia, not a bad price
Order 2 sets just in case they break
D
Daddy454
Spring Creek,NV
