ideas needed for a homemade bolt bin
dukes
I have searched and searched and can find anyone's home made bolt bin. I am going to use plywood to build a bolt. Does anone have pics of their's? Have built one and would do something different?
1320stang
Edmond, OK
I think I'd use 1x instead, poplar would be nice. Slot them halfway thru and slip together, use white bathboard (masonite) for the back. Use 1x2 with a 30 degree cut on the front.
Mattlt
MN
I bought these at an auction. 3 for $5 if I remember correctly. Shelves and sides are 3/4" plywood and drawers are paneling / hardboard.
My next favorite thing to use are half-gallon juice containers. Cut them off to a consistent height with a table saw. Make a frame with 1x lumber and a plywood bottom, like a drawer. I have one cabinet that has angle iron "drawer slides" that these drawers slide on.
StevePgh
Pittsburgh, PA
A friend of mine used to have one that his father made. His complaint was because of gaps between the cubbyholes and in the back of the bin where washers would either drop through, slide under, or get stuck in the cracks. With decent joinery it should be easy to prevent that from happening - if you see potential problem areas, I'd use some caulking to prevent that.
If it were me, I'd go with shelves sized for specific plastic bins with a strip of molding on the front edge of them to prevent accidental pull-outs. There are a huge variety of USA manufactured plastic bins out there. I'd inset the shelves/bins from the front a bit, taking into account the molding from the frame or the front of the box if they protrude a bit in case you wish to mod it later with a cover. For the same reason, if you are not wall mounting it, give it a base to get the bottom shelf at least 2" off the ground/bench. That space on the bottom will come in handy later if you want to make
I've also seen folks use a sheet of poly with a tomato stake rolled up and stapled on the bottom weighting it down and tacked through molding at the top to serve as a cover to prevent debris from getting into the bins. I've also seen someone who mounted a roll-up blind to the top for the same purpose as you can get them both cheap and cut to any width - that would take a slightly different design for the top of the box if you wanted to make it pretty. All of these approaches mean you can't have anything protrude from the carcass. to keep it decently sealed.
Depending on size you can use a piano hinge on the sides with magnetic latches to make a set of doors for it to prevent dirt/dust from getting in the bins. If you are going that far, and you want to REALLY go nuts, I'd make the cover a smaller box about a couple of inches deep on the inside. Use some little screw-in L-shaped hooks that you can use to store small quantities of bagged fasteners where they are easily visible and somewhat organized (think hardware aisle of a hardware store). Then buy ziplock bags with a pegboard hole in 'em and a sharpie to mark what size they are (100 bags each of 2 sizes is around $10 shipped from the site I linked to). I've seen folks do this with cup hooks, but it is hard to get several bags on the same hook without them bunching up. I like the style shown here (style #15, 9586T4, 50 for $7.20).
I have been planning to build something using the hooks and bagged fastener approach, as I find that easier to manage, organize, and KEEP organized than fishing tackle organizers and partially opened bags sitting in bins that I currently have.
crazytrain
Amish Country, Pa
I found a few on line.
Using old soda bottles
Old oil quart bottles
Old jars
My grand father did something like this in his shed. He used a 1x3 and screwed the lids of the jars to it. Then he hung the 1x3's with lids attached to the rafters. After filling the jars full of various nuts, bolts, washers, screws and nails he just screwed them into the lids. At a glance he could look up and see what he needed.
plym49
Old jars
The soda bottle idea is brilliant. You could even stack and glue short lengths of PVC pipe for the rack they slide into.
NUTTSGT
Northern Central Ohio
I made some plywood to make shelves and dividers. On those shelves went some HF bins of two different sizes.
If you search the thread in my sig, you can see the pictures.
D
dukes
I came up with a modular design. the bottom section will be 12" deep, 12" tall and 8' wide, the next will be 8"x8"x8', the next 6x6x8 and the top will be 72 6" bins. I am going to try and draw some plans up and I will try to post them tomorow.
IMCA38
Bennet, NE
Here's mine. I have the exact dimensions in an earlier post.
RBailey
Dubai, UAE (Arabian Gulf)
One of the jobs that has been due for a long time is sorting out all of my my nuts and bolts. I have had a plastic sorting boxes for years but they have always laid on a shelf and not been as organised as I wanted. So a few sheets of plywood and a bit of time with table saw and a router and sorted !
So what is in them all.
Top shelf is for small assortment boxes :-
- Circlips, Split pins, Rivet Nuts, ‘O’Rings, clevis pins, roll pins and springs.
Then in the boxes on the regular shelves one for each :-
- Small screws and self tapping screws.
- Large screws and raw plugs
- Metric nuts and bolts M10 and bigger
- Metric nuts and bolts M8 and smaller
- Washers.
- Imperial nuts and bolts.
- Electrical bits, fuses, relays and heat shrink.
- Electrical crimp terminals.
- Hose clamps and air fittings.
- Abrasive paper (in A4 folder).
- Pop rivets and staples.
- Plastic body clips.
- Batteries.
These are the parts boxes I use. They are a bit flimsy but gluing in the orange removable dividers solved that problem.
The shelves are just screwed and glued into dado grooves I routed into the sides.
Castors to keep it mobile to take to the track / desert.
And a lock, not that I don't trust you but ......
Once I have used it a while and happy nothing needs changing I will hit it with some paint.
Cheers,
Richard B.
