fixture placement
Karl Fields
Getting ready to install my t8/ 4 tube fixtures in the new 48'x36' garage. Ceilings are 12' at edge to 18' at center.
Space will be used for project cars.
Couple thoughts here, one would be starting about 6' from walls and 5 ' between fixtures. That would place 4 rows of lights across the 36' span. Each of the 4 rows would have 5 or 6 fixtures, also about 5' apart. the length of the 48'
Way over kill? Is there a formula for this? Other suggestions? Please??
Ch3No2
I did 3 rows in my 22' wide and 5 deep in 44' and it's daylight at night inside but I did get the double ballast fixtures so I could only have 2 of the 4 tubes on if I wanted and the outside rows are on a seperate switch from the center row so all kinds of possibilities.....
Steevo
43.49600, -112.04300
I used the 8' T8 fixtures with 4x4' tubes, spaced the rows 5'6" apart and 4' off the walls.
I used continuous rows, with no gaps between fixtures.
Not overkill at all.
