Omphaloskeptic
I know it's early in the remodel for the upstairs, but has the new siding made the space seem warmer even without insulation?
I think I'd be hanging out in that upstairs.
have an old bank barn that I'd guess is a bit older than yours, but similar in a lot of ways.
Great work with the Barn... Really a cool project. - I'm just a little west of you (Elverson) and have an old bank barn that I'd guess is a bit older than yours, but similar in a lot of ways.
If you're ever over this way, stop by.
ray
I thought about putting the star back up...
), and you should get a set of 8"x10" color glossy pictures made up of the 'as found' state of the barn. Frame them and mount them next to the man door, so each time you pass through, you can see them and SMILE! J-man, yup a hinged wallI'm quite pleased with the execution on this one. Without that solution, I wouldn't be able to get building materials or furniture up there later. Btw, my current client engagement is in Wilmington, so I do that drive frequently.
The cuts in one stretch were such a PITA due to twisting and leaning and dipping surfaces. It was a curse fest. Attached, see a picture of the oddest cut I've ever made. Notched, and 3 angles cut in the end to make it fit. Plus, I had to use string to line everything up. Got it done, but damn was that a lot of hours for not much progress!
